fuel line size/pump size for 600 hp, 10.50 et car?
Im sure we can get by with -8 line, but what gph pump would be reasonable for 600-650 hp? I know people have ran the holley black (140 gph), and gotten away with it. But is this recommended?
Re: fuel line size/pump size for 600 hp, 10.50 et car?
The 140 pump is fine, it's the restrictive Holley blue regulator to say away from , as it's needle and seat has less flow area then the combined needle and seat area of a 750 Carb!
I've seen fuel diagrams with the regulator plumbed into the return line after the carb, does this work?
#8 will be fine for gasoline. For gas, I was impressed with the Carter Black 15psi race pump. It's electric, smaller than a Holley pump, and more quiet. Come with a nice rubber isolated bracket and it flows a lot of fuel. I wouldn't be afraid to try one on a 600hp car with a largeport regulator.
I run a Mallory 140 pump with their regulator (better flowing than standard Holley regulator). #8 from tank to filter, #8 from filter to pump, #8 from pump to regulator, #6s from regulator to each float bowl. Car ran 10.5s at 126 MPH weighing about 3750#, FWIW.
Yes, you will need to use a bypass type regulator, I prefer this method as you no longer have the possble restriction of the regulator between pump and carb, you always have fresh cool fuel passing right by the carb so available fuel is cooler, you are less likely to get large quantities of trapped air in this type of system so less chance of fuel airation at the n/s = more consistent and better fuel conrtol in the bowl.shiftbyear wrote:I've seen fuel diagrams with the regulator plumbed into the return line after the carb, does this work?
You need a good unrestricted return line to keep fuel pressure stable at lower fuel demand.
[quote="rewguy"]Im sure we can get by with -8 line, but what gph pump would be reasonable for 600-650 hp? I know people have ran the holley black (140 gph), and gotten away with it. But is this recommended?[/quot
If the car will leave you could have a problem with these street pumps, ever wondered why a serious pump has 20 plus PSI coming out of it, theres a reason, and the reason is to over come the Gs on launch. I'd do it right and never worry about it.
- af2
Unless the cell is in front..vortecpro wrote:rewguy wrote:Im sure we can get by with -8 line, but what gph pump would be reasonable for 600-650 hp? I know people have ran the holley black (140 gph), and gotten away with it. But is this recommended?[/quot
GURU is only a name.
i bought a product engineering pump and regulator last year and i really like it. It seems like a high quality unit and its not noisy. Be sure to get one rated for continuous duty if you street drive the car as i do.
The Quick Fuel 30-175Q pump would be a good choice. You can set it up for internal or external bypass. I run one with an external bypass. https://www.holley.com/products/fuel_sy ... /30-175QFTrewguy wrote:Im sure we can get by with -8 line, but what gph pump would be reasonable for 600-650 hp? I know people have ran the holley black (140 gph), and gotten away with it. But is this recommended?
Quick Fuel also makes a Holley-style regulator # 30-803QFT that's a significant step up from the standard Holley regulator. https://www.holley.com/products/fuel_sy ... /30-803QFT
A 600 hp engine probably uses between 40 and 50 gallons per hour of gas at WOT. So not a huge amount of fuel.
Andy F.
AR Engineering
AR Engineering
Early 90's we ran 10.15 in a 3800lb sedan using 1 holley blue pump , pump mounted ~6" above the fuel level drawing thru a factory 3/8" pickup then pushing thru a factory 3/8" line to a holley blue reg then into the carb. Consistent 4.5lb pressure, nice plug colour, all happy!andyf wrote:A 600 hp engine probably uses between 40 and 50 gallons per hour of gas at WOT. So not a huge amount of fuel.
we have run that pump and it is good, but they say it is not for continuous duty. I bought a product engineering pump for my street car because it is rated for continuous duty.tenxal wrote:The Quick Fuel 30-175Q pump would be a good choice. You can set it up for internal or external bypass. I run one with an external bypass. https://www.holley.com/products/fuel_sy ... /30-175QFTrewguy wrote:Im sure we can get by with -8 line, but what gph pump would be reasonable for 600-650 hp? I know people have ran the holley black (140 gph), and gotten away with it. But is this recommended?
You wont beat anyone if you do everything the same as everyone.
If you put the fuel tank (fuel cell) in the front under hood with a single Carter P4594
6psi 74GPH electric fuel pump. Thru a simple 3/8" fuel line. No regulator is required.
Now with the under hood fuel cell you can easily BLEND your race gas with premium pump gas to get the required fuel octane and MORE CONSISTANT performance
and SAVE MONEY. Mount the Carter P4594 pump just beside or just below the under hood fuel cell. No regulator is required.
yep,cjperformance wrote:Early 90's we ran 10.15 in a 3800lb sedan using 1 holley blue pump , pump mounted ~6" above the fuel level drawing thru a factory 3/8" pickup then pushing thru a factory 3/8" line to a holley blue reg then into the carb. Consistent 4.5lb pressure, nice plug colour, all happy!andyf wrote:A 600 hp engine probably uses between 40 and 50 gallons per hour of gas at WOT. So not a huge amount of fuel.
it is amazing these got away with half the stuff they did,undersize fuel lines etc
craig,
a mate of mine that i helped in the 90s ran an ''A'' street HK bathurst monaro
355
fuelie heads
13.8:1 comp
methonol 750 holley on a victor jnr
10.7s @ 128mph on a 9'' slick
actually a competitive car in its day
2 x holley blue pumps through a 7/16 hardline
i would not dream of doing it these days but maybe we are all over thinking it???????
steve c
"Pretty don't make power"
