Hi,
just make back pressure measurement from exhaust pipe(after headers and y-pipe).Pressure gauge reads at end of accelerate(6500rpm) 13kPa(~1.9psi) .Is this too much or acceptable backpressure?This is na 385 sbc.
Exhaust backpressure
Re: Exhaust backpressure
Here's grab from a David Vizard article http://www.superchevy.com/how-to/exhaust/0505phr-exh/
He suggests no more than 0.2 psi (~ 6" H2O), but as you can see, your 1.9 psi should only result in about a 2% loss from open exhaust power
Trivial for proper mufflers.
Remember that's the average, not necessarily what the engine is seeing at TDC. Pressure can swing as low as half the average absolute pressure if header is tuned right.
IMO 2-3 psi would be fine at peak RPMS, in most cases.
Thanks for replys,I was little worried if exhaust system after headers is too small.Engine itself is somewhere 450-500hp range,headers+y-pipe are these: http://www.ebay.com/itm/Maximizer-SBC-E ... 1750439877
and rest of exhaust is one 3" pipe to dynomax ultraflow(3"in 2x2.5" out).
