Rember the intake port texture debates?
BradH
Post by BradH » Mon May 08, 2017 2:08 pm
Well, I guess we can drag up the golf ball-type surface topic again now that a well-known engine builder is offering it as an upgrade to their regular CNC programs: http://www.besracing.com/cylinder-head- ... t-dimpling
:lol:
Carnut1
Re: Rember the intake port texture debates?
Post by Carnut1 » Mon May 08, 2017 3:28 pm
Just add $400 to the cnc price.
BradH
Post by BradH » Mon May 15, 2017 11:27 am
Carnut1 wrote:Just add $400 to the cnc price.
And what do you get for your $$$?
Is this now considered a given way to improve the induction system performance, or does the discussion still go on... just not in this thread? :wink:
mag2555
Post by mag2555 » Mon May 15, 2017 2:14 pm
No debate in my mind from along time ago, like how fast super stockers where even before they threw in the Towel and allowed porting!
Post by 1989TransAm » Mon May 15, 2017 2:33 pm
Does this work better with a carburetor or EFI? Dry air or "wet" air? Or does it not matter?
steve cowan
Post by steve cowan » Mon May 15, 2017 5:40 pm
jim mcfarland was doing the dimpling deal back in the day when he was with edelbrock
intake ports and combustion chambers,its nothing new i personally like the burr finish that * does on his cylinder heads
steve c
user-23911
Post by user-23911 » Wed May 17, 2017 4:14 am
Another marketing gimmick.
Most of the gains are at the seat.
But they look really pretty so must therefore work?
mag2555
Post by mag2555 » Wed May 17, 2017 6:06 am
Highly efficient seats are not the key to real good BSFC numbers!
Caprimaniac
Post by Caprimaniac » Wed May 17, 2017 6:46 am
joe 90 wrote:Another marketing gimmick.
Any w/wo dimpling tests on dyno or track? (Same engine, has to be max-effort deal, heads identical , same CNC shape/volume runners- dimpling ONLY difference)
Someone stated "all pro top teams want them", which do mean it Works?
77cruiser
Post by 77cruiser » Wed May 17, 2017 7:55 am
Normal CNC porting leaves a somewhat rough texture, why would that be better?
Jim
mag2555
Post by mag2555 » Wed May 17, 2017 8:55 am
Velocity changes within a port make for pressure changes.
Pressure changes make for fuel drop out.
Drops of fuel love to cling to a smooth surface and not break back up into finer easy to burn state no less vaporize!
This makes for more fuel being needed to make a given level of power and can lead to fuel wash on the cylinders walls and fast waring rings and Bores.
To prove this happens just place a drop of water on a stone kitchen counter top and then blow on it.
All the water does is stay in a ball, but move around the counter top.
Next place a drop OD water on some 80 to 120 grit sand paper and blow on it, now you will see the ball of water break up into a mist , or at least far finer drops!
user-9274568
Post by user-9274568 » Wed May 17, 2017 9:19 am
smooth or rough, that fuel is on the walls of the manifold/ports, period.
The finer the fuel droplets are (better atomized) in the combustion chamber the faster and more completely they burn. This creates more power out of the same amount of fuel and less emissions because there is less raw and unburnt gas running out of the exhaust.
Rick Finsta
Post by Rick Finsta » Wed May 17, 2017 9:49 am
The fuel puddling is seen very easily in EFI systems with datalogging. In fact, the best systems use OEM-style "wall-wetting" transient algorithms to account for the dynamic conditions that affect addition to and subtraction from the "puddle."
Frankshaft
Post by Frankshaft » Wed May 17, 2017 10:21 am
Ever take a high mileage Ls head apart? You can see the pattern on the port walls where the fuel is spraying and "pressure" washing the port walls, the rest of port usually has a suprising amount of carbon and gook built up on them.
Carnut1
Post by Carnut1 » Wed May 17, 2017 11:34 am
If there was anywhere this would be beneficial a high speed ssr comes to mind. If surface texture would help the air stay attached at higher speed before separation that would make a ssr that is shape challenged perform better.
