need help on tunnelrams
i have 3 tunnel rams an 660,s,,edelbrock proram11,,billjenkins weiand,an another edelbrock7070',, 3500 lbs 55 chevy 406 13.1 220 hand ported pre eliminator heads,shift @7200 go thru the lights the same,turbo 400,5200stall,runnen @ bakersfield,which t ram wud b the best ?? i bought a new revised holley strip dominator to start with an 850 dblpumper,which i had old intake wasa bowtie from back wen 25 yrs ago,car was runen 126,mph,10.50,1.40 60 ft times no trans brake foot brake...
Re: need help on tunnelrams
Calling Bigjoe, calling Bigjoe, I bet he'd have answer to this one with has many as he's used.
- Show Guest
I saw this-- There is very little difference between any of the ones you listed- Probably only 15 HP at the most-- Pick the one that looks the best to you, and go for it
JOE SHERMAN RACING
JOE SHERMAN RACING
Take some measurements on each Manifolds runner expansion rate back towards the Plenum and report back if you would.
Your heads are still very much on the small side Intake runner area wise even with the porting with that CID motor, so this info can make a good pick better.
What gears are in the car?
