tool steel solid lifters questions
Re: tool steel solid lifters questions
Up until the early 50's Chevy and GMC inline 6's had forged steel cams and used chilled iron lifters... When they switched to cast cams the lifters were hardenable iron...
- Alan Roehrich
Well, we have been using Valvoline VR-1 for break in and Royal Purple for racing, but we've had a little trouble lately getting VR-1. We're going to try Brad Penn, some already have, and had good results.Bob Hollinshead wrote:I plan to pull the inner springs out and set the installed height high for the break in. It will see a few 20 minute runs at 2000-3000 rpm with full cool down between. Alan, what oil are you having luck with?
Alan, the Brad Penn works great.Alan Roehrich wrote:Well, we have been using Valvoline VR-1 for break in and Royal Purple for racing, but we've had a little trouble lately getting VR-1. We're going to try Brad Penn, some already have, and had good results.
At some point in the 60s I think they started using cast wax for their cam and lifters, and not much better for the blocks and rods.Truckedup wrote:Up until the early 50's Chevy and GMC inline 6's had forged steel cams and used chilled iron lifters... When they switched to cast cams the lifters were hardenable iron...
I have run the Trend tool steel lifters on a nitrided cast cam with similar spring pressures to Alan. I have also ran a nitrided cast cam with regular Crower EDM lifters with 170 seat and 450 lb open.
Cams are broken in with reduced spring pressure and I only use Brad Penn oil with them.
Lykins Motorsports
brent@lykinsmotorsports.com
www.lykinsmotorsports.com
www.customfordcams.com
