I'd think that it would depend on the case size and porosity of the perforated tube inside it. I'm hoping that a design such as MagnaFlow race muffler or Borla XR-1 with the largest possible case will look like a really big, wide angle version of the second type in DV's graph to the pulses, but look like a straight pipe for the flow. Of course, that graphic by DV is a gross simplification -- but that's why it's useful, presenting 80% of the truth in a format that is easy for people to understand when the remaining 20% of the truth is highly application specific.Carnut1 wrote:D.V. artwork. Posted for reference of straight through muffler design.
In any case, my car has turbos. I've come to the conclusion that given the pressure ratio and flow velocity at the wastegate and turbine, the pulse tuning downstream of the turbine doesn't impact power at full load and high rpms. I've come to this conclusion that many other people would call obvious via a torturous and long route! . What I care about in my exhaust and mufflers is low back pressure at high rpms and loads and great broadband muffling at low rpms and loads. For that purpose, a straight thru design with perforated tube(s), packing, and biggest possible case should be the winning ticket.
