Pontiac 400 screw in studs
ProPower engines
Post by ProPower engines »
Hey guys
I am trying to locate a replacement screw in stud to convert some press in studs in a pont. 400.
The stud hole is .434" with the stock press in stud removed making it necessary to install inserts into the heads to reduce the hole to 7/16 X 14 thread.
I don't see anything readily available that uses a 1/2" thread that will work on these heads.
Other then inserts any suggestions on studs
Dave
wyrmrider
Re: Pontiac 400 screw in studs
Post by wyrmrider »
I've used 1/2 x 7/16 studs but not recently
they should still be available
round up the usual suspects
I don't see them in
ELGIN
GOSFAST
Post by GOSFAST »
Hi Dave, ARP has them for the Pontiac application.
Thanks, Gary in N.Y.
P.S. Part number, 290-7201, should be available?
Sept. 2019 - Drag-Week Winner - New York Street Ride 7.23+ @ 196+ @ 3800#+
ProPower engines
GOSFAST wrote:Hi Dave, ARP has them for the Pontiac application.
Thanks Gary
I did see something but was unsure if they were applicable to the pontiac head issue.
I will contact ARP and get more details tomorrow.
Dave
Post by pdq67 »
Thanks Gary
Dave
Are these the studs that had the oil coming through the middle of them to lube the rockers and balls??
tjs44
Post by tjs44 »
Only pre 65 had stud oiling.Tom
ProPower engines
Same exact stud design but no center oiling to rockers.
The later heads I have are not drilled for the rocker oiling.
John Wallace
Post by John Wallace »
Screw in stud
The boss may have to be milled down to account for the hex head of the stud.
(to get the correct height for the rocker ball)
John Wallace
Pontiac Power RULES !
www.wallaceracing.com
John Wallace
From Butler:
Fasteners
John Wallace
tjs44
Post by tjs44 »
John,later heads that have the guide plates bolted to the heads I believe dont have to be milled.The early heads without guide plates usually do if a shouldered stud.There were studs out there that were screwin but no shoulder that would not require to be milled.I think Isky made them.Tom
wyrmrider
Post by wyrmrider »
Dorman used to have these studs but NLA 370?
ProPower engines
Thanks Guys
I found the ARP studs in stock in Ohio.
They are the 1/2 X 7/16 just for these heads.
They are on the way now :D
Thanks again
Dave C
SupStk
Post by SupStk »
As mentioned ARP makes a 7/16 stud with 1/2 bottom. Don't recall having to mill the bosses on '66 up Pontiacs when converting to screw ins.
Pioneer made 3/8" studs without the hex. They had a 7/16 bottom. Number was something like RS-348?
Monty Frerichs
B&M Machine
