427dart wrote:Found some info from a person involved with the 426 street hemis at Chrysler regarding the actual compression of a stock 426 hemi as delivered.
It calculated out to 8.5 to 1 even though the factory rated it at 10.25!
This was due to the large amount of material left on the block deck height and on the cylinder heads. Chrylser always made note of how much to cut from block and heads when blueprinting these engines.
Now when you installed the factory Race Hemi 12.5 pistons without any mill work done you really had 10.5 to 1 compression.
And to think back in the day,for us it was 1970, it was only Sunoco 260 going in the tank of our then stock 1970 Hemicuda!
Imagine how much stronger the average stock Street Hemi may have been with the true 10.25 compression!!!
I wonder how far off the mark other makes were during the 60's -70's?
this is 1970 Street Hemi to NHRA Specs :
439.2cid
NHRA 425HP / 426cid
167.7 CC Chambers
88.3 CC Domes ( Dome Height= .536" )
.018" minimum thickness HeadGasket
11.36:1 to as high as 11.725:1 CR ???
