4.3 vortec v6 OBD2 build
overS10ded
Post by overS10ded »
I'm building a chevy '96 OBD2 Vortec v6. I have many questions but am still planning and collecting parts. First question is about the use of performance balancer/damper with the crank position reluctor ring. I believe the OBD2 w/crank snout mt reluctor wheel pinched in place by the balancer/damper uses a shorter hubbed damper??
Good times!
Bruce
midnightbluS10
Re: 4.3 vortec v6 OBD2 build
Post by midnightbluS10 »
Look for an 02 or later engine that uses mpfi instead of poppet valves for the injectors. Unless youre planning on using a marine manifold with standard injectors or an edelbrock manifold...then disregard . They also have the better ecm, the 0411. You can go even newer than that and gain distributorless ignition and a few other useful bits.
You can go over to syty.net and check out what they're doing, too. Back in the day, they were on top of 4.3L performance. But I suspect the info there is getting stale. Still, it's a valuable resource for all things 4.3L they've been swapping 96+ Vortec shortblocks into their trucks for a while. I'd start there.
JC -
groberts101
Post by groberts101 »
I've built several of them(V6 and V8) for my work trucks/vans and others toys through the years. What's the chassis?
Have tons of parts left over too if you're interested. Fully ported/epoxied heads(LS valve/beehive spring conversion) with matching ported/epoxied intake. Some bored and ported OEM and granatelli MAF's. Couple cold air induction kits. Also have the updated MPFI mini-injectors mentioned above with extremely low mileage(well under 10k) and VMax intake manifold spacer kit. PM me if interested.
overS10ded
midnightbluS10 wrote:Look for an 02 or later engine that uses mpfi instead of poppet valves for the injectors. Unless youre planning on using a marine manifold with standard injectors or an edelbrock manifold...then disregard . They also have the better ecm, the 0411. You can go even newer than that and gain distributorless ignition and a few other useful bits.
The engine I am using is the '96 I mentioned. I have run a ProCharger w/Marine manifold conversion, 44# inj, 0411 PCM and EFILive for tuning for 8 years and over 30,000 miles of DD use, when I'm in the states. I am familiar with the other forums and I AM there too. Trying to ask good questions. Trying to find good info!
Good times!
Bruce
groberts101
make sure you use the updated aluminum intake gaskets. far superior to the plastic versions.
overS10ded
Steel harmonic balancer for '96 w/reluctor wheel
What performance harmonic balancer/damper options are there for a 4.3 with the reluctor ring on the crank (which is pinched in place between balancer/damper and crankshaft). I am running a ProCharger centrifugal and I want a better balancer than the stock cast iron one-steel would be better. I have found a TCI "Rattler" however I am wondering about the KS getting false readings from their 9 ball system-that evidently rattles. I sent a message asking ATI about my application on their website several days ago. Right-no answer! So I have read through 100's of forums and the other option is to machine down the snout .100 +/- off a performance balancer for a earlier non-obd2 engine. Just compare the oem that came off and have the new balancer snout machined to same length. I guess that might be the way to go but hoping someone has built a 4.3 here that used something other than oem damper.
Good times!
Bruce
