Reversion/charge contamination during overlap is what causes the motor to run rough until it "comes up on the cam". Coming up on the cam is when reversion/charge contamination is no longer occuring, and the column of exhaust gases exiting the exhaust port and header tube has enough momentum to start clearing the combustion chamber/intake port of exhaust gases, and starts bringing in a fresh air/fuel mixture into the chamber and cylinder. The question asked was about overlap. Camking didn't specifically say that the column of exhaust gas exiting through the exhaust port and header tube drawing on the intake port when both valves are open, is overlap.hoffman900 wrote: ↑Fri Dec 01, 2017 3:41 amAll that applies with overlap as well. An engine works off of pressure differentials, no matter what part of the valve timing curve it’s at. If none of the above exist, you get reversion / charge contamination, overlap or not.408 Nova wrote: ↑Fri Dec 01, 2017 3:36 amThis description sounds more like normal operation, without taking into account the affects of overlap on the engine.CamKing wrote: ↑Thu Nov 30, 2017 11:05 am
Easy. Air is flowing from higher pressure to lower pressure.
As long as the pressure above the exhaust valve, is lower then the pressure below the exhaust valve, air is flowing out of the combustion chamber, into the exhaust port.
As long as the pressure below the intake valve is lower then the pressure above the intake valve, air is flowing out of the intake port, and into the combustion chamber. It doesn't matter where the piston is.
Valve overlap
Re: Valve overlap
Re: Valve overlap
You and me both... plus I have to pitch my bomber sponsorship proposal....piston guy wrote: ↑Thu Nov 30, 2017 1:39 pmPerfect , simple terms explanation Mike. It also shows how a piston in motion alters the dynamic and can cause reversion. The only other thing that "can" hurt flow at overlap is a giant dome on a piston , especially if it is an opposing valve ( hemi) head.CamKing wrote: ↑Thu Nov 30, 2017 11:05 amEasy. Air is flowing from higher pressure to lower pressure.
See you next week "to pick up a sticker " LOL
Re: Valve overlap
Overlap is exactly as Mike stated, pressure differentials.408 Nova wrote: ↑Fri Dec 01, 2017 4:43 amReversion/charge contamination during overlap is what causes the motor to run rough until it "comes up on the cam". Coming up on the cam is when reversion/charge contamination is no longer occuring, and the column of exhaust gases exiting the exhaust port and header tube has enough momentum to start clearing the combustion chamber/intake port of exhaust gases, and starts bringing in a fresh air/fuel mixture into the chamber and cylinder. The question asked was about overlap. Camking didn't specifically say that the column of exhaust gas exiting through the exhaust port and header tube drawing on the intake port when both valves are open, is overlap.hoffman900 wrote: ↑Fri Dec 01, 2017 3:41 amAll that applies with overlap as well. An engine works off of pressure differentials, no matter what part of the valve timing curve it’s at. If none of the above exist, you get reversion / charge contamination, overlap or not.
That is really how the whole engine operates.
Re: Valve overlap
Does anybody except me get excited about the Ideal Gas Law? PV=nRT?
It, along with pressure differentials, explains SO MUCH about what is going on in an internal combustion engine.
paulie
paulie
Re: Valve overlap
Overlap is exactly as Mike stated, pressure differentials.Warp Speed wrote: ↑Fri Dec 01, 2017 7:49 amReversion/charge contamination during overlap is what causes the motor to run rough until it "comes up on the cam". Coming up on the cam is when reversion/charge contamination is no longer occuring, and the column of exhaust gases exiting the exhaust port and header tube has enough momentum to start clearing the combustion chamber/intake port of exhaust gases, and starts bringing in a fresh air/fuel mixture into the chamber and cylinder. The question asked was about overlap. Camking didn't specifically say that the column of exhaust gas exiting through the exhaust port and header tube drawing on the intake port when both valves are open, is overlap.408 Nova wrote: ↑Fri Dec 01, 2017 4:43 am [quote=hoffman900 post_id=702610 time=1512117681 user_id=20313
[/quote]
A basic 4-stroke engine like we’re talking about here works off of pressure differentials created by a piston. Overlap is an entirely different thing.
Re: Valve overlap
You need the separation between the lobe to achieve the proper 4 valve events and overlap to properly deal with those pressure differentials so is it really meaningless?All that applies with overlap as well. An engine works off of pressure differentials, no matter what part of the valve timing curve it’s at. If none of the above exist, you get reversion / charge contamination, overlap or not.
Some engines need more some need less but they are still things that need to be understood when building an engine.
There have been 2 stroke engine that don't use rings and they don't need valves so should I throw out learning about rings, valves and valve seat angles for my V8?
Re: Valve overlap
That's where you're wrong.
It's all about pressure differentials.
The piston motion is just partially responsible for the pressure differentials.
We have positive flow before TDC, because the exiting exhaust causes a low pressure area below the intake valve during overlap.
We also have positive flow after BDC, because the velocity of the flow in the port, and the closing intake valve, keep the pressure above the intake valve higher then the pressure below it, even though the piston is on it's way back up.
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
Jones Cam Designs
Denver, NC
(704)489-2449
Re: Valve overlap
Shush. That's top secret.Warp Speed wrote: ↑Fri Dec 01, 2017 7:49 am Overlap is exactly as Mike stated, pressure differentials.
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
Jones Cam Designs
Denver, NC
(704)489-2449
Re: Valve overlap
If you keep giving away valuable information there will be little left for us to sell.CamKing wrote: ↑Fri Dec 01, 2017 10:29 amShush. That's top secret.Warp Speed wrote: ↑Fri Dec 01, 2017 7:49 am Overlap is exactly as Mike stated, pressure differentials.
Re: Valve overlap
It's really as simple as watching water flow down hill, into a pond.
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
Jones Cam Designs
Denver, NC
(704)489-2449
Re: Valve overlap
Engines "can" run without overlap because of pressure differential caused by piston motion alone. Taking advantage of pressure differential created by residual motion ( exhaust gas flow /vacuum) with the use of overlap in valve timing can be very beneficial additionally.
Is that "scholarly" enough LOL May be what 408 nova was getting at.
Re: Valve overlap
Even if there’s zero valve overlap, at many rpms the engine intake will still breathe based on exhaust scavenging. If you pull a vacuum in the combustion chamber and close the exhaust valve, the vacuum is still there when the intake valve opens.piston guy wrote: ↑Fri Dec 01, 2017 2:05 pm Engines "can" run without overlap because of pressure differential caused by piston motion alone. Taking advantage of pressure differential created by residual motion ( exhaust gas flow /vacuum) with the use of overlap in valve timing can be very beneficial additionally.
Put Search Keywords Here
Re: Valve overlap
If you forget about 4 strokes and read up on 2 stroke exhaust systems, you will see the real meaning of "coming on the pipe". The exhaust pulsing may pull in intake mix while the piston is at the bottom of the stroke.
https://search.yahoo.com/yhs/search;_yl ... &fr2=12642
I've seen small 2 stroke engine HP claims as high as 6 HP per cubic inch, normally aspirated, achieved without valves, and never any concerns about valve float.
Kirkwoodken
Kirkwoodken
Re: Valve overlap
I tend to think a lot of future 4 stroke power will come from the exhaust side as we learn how to better develop it.kirkwoodken wrote: ↑Fri Dec 01, 2017 2:57 pm If you forget about 4 strokes and read up on 2 stroke exhaust systems, you will see the real meaning of "coming on the pipe". The exhaust pulsing may pull in intake mix while the piston is at the bottom of the stroke.
It seems over the years of 4 stroke development overlap has decreased...
