If you define that LSA is how far apart the lobes are on the cam then yes they don't, as there are normally atleast 2 cams. If you look at it or think of it as the average of the ICL and ECL or how far apart the centrelines are In cam degrees then yes they do as the number is defined even if many are variable nowadays
Valve overlap
Re: Valve overlap
Re: Valve overlap
Was it Nissan YD/ ZD or was it Ford / Mazda.......?
DOHC but each stick does 1 intake and 1 exhaust?
Someone knows?
Otherwise everyone's just making it all up as they go?
Otherwise with normal DOHC, you tweak the cams and you've got a fixed LSA you can refer to?
But it's adjustable depending on what you've got?
Someone knows?
- John Wallace
Re: Valve overlap
Isn't LSA (Lobe Separation Angle) the separation angle of the intake lobe and exhaust lobe?If you define that LSA is how far apart the lobes are on the cam then yes they don't, as there are normally atleast 2 cams.
Doesn't say anything about it having to be on the same camshaft?
Same as the overlap?
Now duration, no can't be changed.
Isn't it why the DOHC so good, you can vary these previously non-changeable events after ground?
If one wants a tighter LSA, change the separation, no need to grind a new camshaft.
If you have your favorite intake cam lobe and your favorite exhaust cam lobe, you can put them at whatever IO and EO you want?
(without needing to have multiple camshafts laying around)
John Wallace
Pontiac Power RULES !
www.wallaceracing.com
Re: Valve overlap
LSA is just an average is is relatively meaningless.
Most people when talking DOHC talk cam centerlines, which tells you wayyyy more. Nothing stopping people from doing the same with single cam engines, other than marketing.
-Bob
- John Wallace
Re: Valve overlap
About like calling a rose by another name?Most people when talking DOHC talk cam centerlines
John Wallace
Re: Valve overlap
It just distinguishes between a LSA of 106* which can mean just about anything centerline wise as long as it averages 106. A cam with centerlines 106/106 is going to perform differently than a 100/112 centerline cam.John Wallace wrote: ↑Thu Nov 30, 2017 9:39 amAbout like calling a rose by another name?Most people when talking DOHC talk cam centerlines
Since people think in terms of centerlines and LSA’s in that world, they don’t get bogged down with marketing speak and “rules of thumb” that is so prevalent with the V8 stuff.
-Bob
Re: Valve overlap
I think we've all stuck our proverbial flags in the sand so is there really anything left to say here?
Re: Valve overlap
128 is grasping at straws.
Think about it Gary. The only thing LSA determines is the deg of separation between peak intake lift and peak ex lift. It defines no valve events/overlap/ or the piston position those 2 peak lift points happen at since the cam can be installed on any IVC. Only the deg of separation between them.
How could that be the most important thing ??
Re: Valve overlap
LSA is a term that was introduced, for the sole purpose of grinding an OHV camshaft.
The guy grinding the cam, doesn't understand opening and closing points. He just wants to know how many degrees to move the master, when going from grinding the exhaust lobes, to grinding the intake lobes. LSA is a machining term, not a design parameter. Cam companies listed LSA, because it was easier for their customers to understand. When I design a cam, I'll tell the customer it's ground on a 107 LSA, just because it's easier then telling him, its a 102 ICL and 112 ECL cam.
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
Jones Cam Designs
Denver, NC
(704)489-2449
Re: Valve overlap
Easy. Air is flowing from higher pressure to lower pressure.
As long as the pressure above the exhaust valve, is lower then the pressure below the exhaust valve, air is flowing out of the combustion chamber, into the exhaust port.
As long as the pressure below the intake valve is lower then the pressure above the intake valve, air is flowing out of the intake port, and into the combustion chamber. It doesn't matter where the piston is.
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
Jones Cam Designs
Denver, NC
(704)489-2449
- midnightbluS10
Re: Valve overlap
Ford/Mazdajoe 90 wrote: ↑Thu Nov 30, 2017 6:33 am Was it Nissan YD/ ZD or was it Ford / Mazda.......?
Someone knows?
I know Mazda had the SkyActiv system that had an eccentric shaft inside the camshaft. I think it was skyactiv, anyway.
JC -
Re: Valve overlap
Perfect , simple terms explanation Mike. It also shows how a piston in motion alters the dynamic and can cause reversion. The only other thing that "can" hurt flow at overlap is a giant dome on a piston , especially if it is an opposing valve ( hemi) head.CamKing wrote: ↑Thu Nov 30, 2017 11:05 amEasy. Air is flowing from higher pressure to lower pressure.
See you next week "to pick up a sticker " LOL
Re: Valve overlap
I never said it was most important but if your intake center-line is optimized and your lsa is wrong then your exhaust center-line will not be optimum.randy331 wrote: ↑Thu Nov 30, 2017 10:39 am128 is grasping at straws.
If it did not matter then we would all be running Comp shelf cams on 110 lsa
Re: Valve overlap
This description sounds more like normal operation, without taking into account the affects of overlap on the engine.CamKing wrote: ↑Thu Nov 30, 2017 11:05 amEasy. Air is flowing from higher pressure to lower pressure.
Re: Valve overlap
All that applies with overlap as well. An engine works off of pressure differentials, no matter what part of the valve timing curve it’s at. If none of the above exist, you get reversion / charge contamination, overlap or not.408 Nova wrote: ↑Fri Dec 01, 2017 3:36 amThis description sounds more like normal operation, without taking into account the affects of overlap on the engine.CamKing wrote: ↑Thu Nov 30, 2017 11:05 amEasy. Air is flowing from higher pressure to lower pressure.
-Bob
