496 BBC Build
cjperformance
Re: 496 BBC Build
Post by cjperformance »
tuffxf wrote:Gday Mark,
Awesome results!
You need to get that thing in the car and have a run and post a timesheet once the setup is sorted.
Norms, look through some of marks older posts and results.
Don't ever think you can only achieve x amount of flow or hp out of a combo just because that is all that most people can achieve.
Cheers
Paul
Oh so true !
KnightEngines
Re: 496 BBC Build
Post by KnightEngines »
Big LOL to the guys that reckon 300cfm is big for a set of 049's.
I've ported just 1 set of them, with a 2.19" valve, good valve job & pocket port & they went better than 290cfm - I am in no way any kind of expert with BBC heads & I got those numbers barely trying.
I feel for Mark, his location & the required correction kinda makes his results a hard sell, but from what I've seen his engines back up the dyno numbers in the car, so I guess he's got a handle on the correction.
vortecpro
Re: 496 BBC Build
Post by vortecpro »
I go to work and I come back to a fire storm LOL. For those who forgot...........773.9 HP @ 6800 RPM on that happy dyno produced this @ 3600 pounds. BTW it was 561 observed HP in a 24.04 baro.........
Back to back dyno tests from my shop to 800 feet elevation conducted by Super Flow
http://www.chevelles.com/forums/13-perf ... today.html
Peanut port 236 casting flow with 2.190 valve, 4.350 bore, SF 600
.200 153
.300 227
.400 269
.500 300
.540 306
ClassicComp
Re: 496 BBC Build
Post by ClassicComp »
That was John Wilsons car? Thought that had 781s?
results speak for themselves
vortecpro
Re: 496 BBC Build
Post by vortecpro »
ClassicComp wrote:That was John Wilsons car? Thought that had 781s?
It is, and it does have 781 heads. I have many many examples of dyno testing in conjuction with track testing.......we race! But right now I have to get the ex figured out on my Buick stocker!
https://youtu.be/E8MsOGkaQus
Bob Hollinshead
Re: 496 BBC Build
Post by Bob Hollinshead »
NormS wrote:You guys can believe what you want to believe . Look at Stan Weiss' flow data for 049 heads. Dr J's head is the only one there that has flow much over 300. Is Vortecpro using a pair of Dr J heads?
you are way off, even a rookie can do it: viewtopic.php?f=1&t=46062&p=656751#p656751
Pro question poster.
Racing68
Re: 496 BBC Build
Post by Racing68 »
Here's what i got with a 2.19 valve
.100 73.8
.200 152.3
.300 226.1
.400 285.6
.500 323.7
.600 338.0
.700 338.0
This build was not a max HP build and still made 700 on a 460" engine
vortecpro
Re: 496 BBC Build
Post by vortecpro »
Stan Weiss wrote:OK, do I think that vortecpro did anything wrong or played any games to get higher numbers? NO All of the numbers he posted look within normal ranges and calculate to 805 HP.
Is his location out of the range of where the Super Flow software is accurate? Possible
There have also been discussions about how the Super Flow software works and way as the correct factor gets greater its results are higher than other dynos / software.
http://www.yellowbullet.com/forum/showt ... 70&page=29
Stan
Stan-consider this:
If you have an engine on my dyno @ 6400 feet elevation and it makes 580 measured or observed HP in a 23.80 baro, the corrected STP HP is 821 HP It is put into a 3400 pound car and runs 138.7 mph at a track thats 4800 feet elevation, 8000 DA, 25.00 baro. This same exact car is taken to a near sea level track 30.0 baro 715 DA and runs 146.34 MPH, if you use your programs you will see you might want to consider re thinking the yellow bullet thread on correction factors at high altitude. My own back to back testing shows almost no difference.
My testing shows
580 observed dyno HP, 821 STP corrected HP
3400 pounds @ 4800 feet elevation 137.7 MPH=708 HP https://youtu.be/p435ml9xCGw
3400 pounds @ 40 feet elevation 146.34=831 HP https://youtu.be/E1Wz5qZDPAk
fastblackracing
Re: 496 BBC Build
Post by fastblackracing »
Vortecpro, Thanks for your contributions that you make here, I for one look forward to what you share and have learned a good bit from you....dont let a nay sayer or 2 ruin the deal as you have the black top dyno results to back up your numbers like straub said.
I loves me some 67 chevelles, had 2 of them and that red one is a wicked machine...Nice job.
BILL-C
Re: 496 BBC Build
Post by BILL-C »
I recently purchased a new Centroid A560 PB 5 axis CNC machining center. For our training program, my son and i chose to digitize one of our ported 049 castings and make a conservative program that will not be risky thin. There is a solid .050 shift in casting location from "blueprint" spacing that isn't really a problem when hand porting, but is a real concern when cnc porting. With stock GM 2.190 and 1.88 valves robbed from a cracked rectangular port head, we got mid 340's cfm on good runer, high 330's on bad SO FAR. Not done yet! I think there's another 10 numbers in there without going kamikaze.
Carlquist Competition Engines
turbotater
Re: 496 BBC Build
Post by turbotater »
bill=c
will you be doing other peoples heads with this program?
i "assume" this program fits 781's as well ?
thanxs
mike
BILL-C
Re: 496 BBC Build
Post by BILL-C »
After i do a few more tweaks to program we will be porting these heads for customers. I'm a firm believer that the oval port heads are the best factory heads to start with as long as the right port work is done. We will need to digitize a 781 casting to see if same program can be cut into them, but if not, i'll just make another program! Vortecpro definately gets better results than most, but i don't see any reason to doubt his claims. In all honesty, i thought i was doing pretty good with this combo, but Mark has me beat by a little -- for now. Competitors that work hard with their hands and heads to get outstanding results should be aknowledged and used as inspiration to get better. Good job Mark!
Carnut1
Re: 496 BBC Build
Post by Carnut1 »
Well said..
vortecpro
Re: 496 BBC Build
Post by vortecpro »
BILL-C wrote:I recently purchased a new Centroid A560 PB 5 axis CNC machining center. For our training program, my son and i chose to digitize one of our ported 049 castings and make a conservative program that will not be risky thin. There is a solid .050 shift in casting location from "blueprint" spacing that isn't really a problem when hand porting, but is a real concern when cnc porting. With stock GM 2.190 and 1.88 valves robbed from a cracked rectangular port head, we got mid 340's cfm on good runer, high 330's on bad SO FAR. Not done yet! I think there's another 10 numbers in there without going kamikaze.
What address do I send the pallet too? :D
BILL-C
Re: 496 BBC Build
Post by BILL-C »
Call me at shop 860-274-0742 EST.
