Scat Pro Comp 4340 I-Beam
Re: Scat Pro Comp 4340 I-Beam
Ditto what needforspeed said. Unfortunatly in N.Ms I see a lot of these rods( Eagles also) an after you disassemble/clean an re torque them most need a adjustment or resize, an the pin clearance set. Like they are put up with a lot of stress. After that most are good to go. Best bang for the buck, but not out of the box! I don't consider +- 2 grams to be balanced either.
Thanks for the good info guys. I will have my machine guy check them and fix whatever they need. He will also be balancing it too.
Got our new Ross 99475 18° Flat Tops today, very nice looking!
