modok wrote:That's a good standard.machinedave wrote:
For the most part I use 70 grit stones until I am .003" to final size then I switch to 220 grit stones until .0005 to final size then I switch to 280 grit stones. After reaching final size I check back every few hours and recheck the bore sizes. I like to leave it sit overnight and recheck in the morning. I have experimented with IR thermometers and found some interesting results. You can measure the cylinders of the block with a temperature at 70 degrees hours after you've last honed the block and come back the next day and check the block at the same 70 degrees and have it shrink by .0002"-.0003". After I am satisfied that the block is done shrinking then I install the honing brushes and make just two strokes up and down with light pressure.
I have a slightly different take on it. Mostly 220 is my base finish, so I set the size in this step. So I hone basically to indicated size(measured hot, so probably .0005 short), then let it sit, then come back later and hone some more as needed, so I essentially finish the cylinder to the base finish being .0002-.0005 short of my actual target size (depending on what follows).
THEN, when I am satisfied with it, I hone a --limited number of strokes-- of 280 and/or 400 and/or a brush (depending on app) and then it's done. If it ends up a few tenths smaller than I wanted I am NOT going to go back and hone any more, if it's one or two tenths over..... too bad, it's done. Not sure if there is a name for that.
Plenty good enough for 99.2% of most engines built?
