Lifter bushings
Lifter bushings
Recently had al pontiac on dyno and had to reject because of low oil pressure. Found few issues one being most lifter bores being at.003+ and was wondering how much press to use when installing bronze bushings in an al block?
Len C
Len C
Re: Lifter bushings
If you are using the std 1" od bushing lube and use .001 press fit.LCaverly wrote:Recently had al pontiac on dyno and had to reject because of low oil pressure. Found few issues one being most lifter bores being at.003+ and was wondering how much press to use when installing bronze bushings in an al block?
Len C
If using the BHJ tooling the fit is taken into account when using their bushings/tooling etc.
That said why not save the cost of bushing the block and just step up a diameter in lifter size??
Re: Lifter bushings
X2, in most cases, for just going to the next larger diameter. However, the OEM Pontiac blocks have unsupported lifter bores and whether larger or bushed back stock, they get weaker and if good springs and aggressive lobes, some bores are likely to pop right off the block. The fast guys pour the lifter valley full of epoxy and/or use bolted in support plates.ProPower engines wrote:If you are using the std 1" od bushing lube and use .001 press fit.LCaverly wrote:Recently had al pontiac on dyno and had to reject because of low oil pressure. Found few issues one being most lifter bores being at.003+ and was wondering how much press to use when installing bronze bushings in an al block?
Len C
Re: Lifter bushings
Jack
can you still get os lifters?
.875 is less than 1"
you'll need new pushrods- but may anyhow
Pontiac lifter oil bands are special IDK if Fords work (or MOPAR/AMC)
anybody use thin sleeves?
HV oil pump?
HV oil pump?
Re: Lifter bushings
This is an aftermarket aluminum block and I don,t think .001 is enough press as the lifter bores will grow almost that much . The owner has already spent big bucks on lifters and it will be cheaper to bush the bores. I do fill all the lifter valleys on my OEM pontiacs with epoxy.
Len C
Len C
Re: Lifter bushings
Youre right.. thats not nearly enough.. downright horrible advice! I would call the mfgr directly but my bill mitchell ALUMINUM BLOCK calls for about. 004 - .006 thou of bushing interference fit. Ideally you should base it on the normalized heat range the motor typically runs in. Cold alcohol motor would be different interference fit than say a summertime street/bracket racer would run.LCaverly wrote:This is an aftermarket aluminum block and I don,t think .001 is enough press as the lifter bores will grow almost that much . The owner has already spent big bucks on lifters and it will be cheaper to bush the bores. I do fill all the lifter valleys on my OEM pontiacs with epoxy.
Len C
Also very helpful to preheat the block after the cold clearances are finalized. Then chill the bushings in the freezer or preferably with dry ice and they'll go in much easier.
Re: Lifter bushings
too bad aluminium block was not mentioned in first post
what's the best lube for brass in aluminium
Re: Lifter bushings
LCaverly wrote:Recently had al pontiac on dyno Len C
Think it was.wyrmrider wrote:too bad aluminium block was not mentioned in first post
Monty Frerichs
B&M Machine
B&M Machine
- New Member
Re: Lifter bushings
Never seen aluminum, abbreviated in this way. I didn't get it either until I read on.
Re: Lifter bushings
.004 is way too much. It will mushroom badly when you press it in and you will have a really hard time get it to hone straight and true unless you leave the id way undersized .002-.0025 is plenty of crush. I lightly knurl a 1/4" band at the top part where it enters the bore and put loctite on the knurled area. dont loctite lifter bore or anywhere else or it will mushroom when you install it
Re: Lifter bushings
Is a mushroom close to a banana where lifter bores are concerned??
Speedbump
Re: Lifter bushings
Several years ago we installed bronze bushings in a couple BBF Alum blocks. We used .005 press. We heat the blocks in an oven to install them. Then size the hole with a hone and reamer after installation. I am not aware that there were ever any problems with the installation with either block. We make all our bushings in house
Re: Lifter bushings
jsavani wrote:Several years ago we installed bronze bushings in a couple BBF Alum blocks. We used .005 press. We heat the blocks in an oven to install them. Then size the hole with a hone and reamer after installation. I am not aware that there were ever any problems with the installation with either block. We make all our bushings in house
key word being reamed then honed. So when 2-3 strokes of the hone takes you from a little tight to a little loose. then what? heat the block again to install a bushing? I buy shelf 660 bronze bushing and machine them to needs so I can leave my bushing a long as possible I even grind clearance for the link bars and let them protrude into the cam tunnel.
Re: Lifter bushings
Best if you have BHJ or lifter tru tooling and install small id bushings and machine- reem to round then touch up with a hone
just using a hone will never get it right
