SBC angled sparkplug headers.
What brand(s) and hopefully part number(s) angle plug headers is everybody running?
SBC
4-tube, long-tube
1-5/8" x 2-1/2" or 1-3/4" x 3"
ANGLED SPARKPLUG HEADS.
Thanks in advance,
SBC
4-tube, long-tube
Thanks in advance,
Re: SBC angled sparkplug headers.
As long as you have the close ratio steering box.. these will work with angle plug heads..
1967 CHEVROLET CAMARO Hooker Super Competition Headers 2131-1HKR
Sure ain't 200.00 $$$ like back in 67'... more like 750.00
pdq67 wrote:What brand(s) and hopefully part number(s) angle plug headers is everybody running?
SBC
4-tube, long-tube
Thanks in advance,
What chassis what year car etc etc etc
Hedman #65003, 1-3/4" x 3", fits '67-69 Camaro and '68-74 Nova. Amazing fit for an out-of-the-box lower cost offering, have them on my '72 Nova. Didn't have to modify or ding a tube for plug clearance, just a slight dimple at #3 cylinder tube at the flange for better bolt access. Clears the Saginaw 800 power steering box and also the 625 manual steering box nicely. Hedman does say it won't clear the close ratio 825 box, but I have no idea about that....I had the 800 power box and swapped it to the 625 manual box. Didn't even have to unbolt the header to remove and replace the steering box, and the same with a full size hi-torque factory starter on the other side.
Hookers suck ass and fit like shit. You'd think they would get the fit right after 40 damn years, but Hooker hasn't.
'67 350SS/RS Camaro 4-speed car. Its an SS/RS because I checked the SS option before the RS option is all back in Oct., '66. About forgot the RS option!ProPower engines wrote:pdq67 wrote:What brand(s) and hopefully part number(s) angle plug headers is everybody running?
SBC
4-tube, long-tube
Thanks in advance,
Thanks Eric,Ericnova wrote:Hedman #65003, 1-3/4" x 3", fits '67-69 Camaro and '68-74 Nova. Amazing fit for an out-of-the-box lower cost offering, have them on my '72 Nova. Didn't have to modify or ding a tube for plug clearance, just a slight dimple at #3 cylinder tube at the flange for better bolt access. Clears the Saginaw 800 power steering box and also the 625 manual steering box nicely. Hedman does say it won't clear the close ratio 825 box, but I have no idea about that....I had the 800 power box and swapped it to the 625 manual box. Didn't even have to unbolt the header to remove and replace the steering box, and the same with a full size hi-torque factory starter on the other side.
I hope for ANGLE PLUG HEADS?
I will look them up.
Many people over look these Headers I bought a pair for my 68 Camaro along time ago
they fit very good with angled spark plugs If I remember I used a short spark plugs
http://www.schoenfeldheaders.com/
Malvin
" Keep away from people who try to belittle your ambitions. Small people always do that but the really great make you
feel that you, too, can become great". By Mark Twain
Yes, they fit both angle and straight plug heads.pdq67 wrote:Thanks Eric,Ericnova wrote:Hedman #65003, 1-3/4" x 3", fits '67-69 Camaro and '68-74 Nova. Amazing fit for an out-of-the-box lower cost offering, have them on my '72 Nova. Didn't have to modify or ding a tube for plug clearance, just a slight dimple at #3 cylinder tube at the flange for better bolt access. Clears the Saginaw 800 power steering box and also the 625 manual steering box nicely. Hedman does say it won't clear the close ratio 825 box, but I have no idea about that....I had the 800 power box and swapped it to the 625 manual box. Didn't even have to unbolt the header to remove and replace the steering box, and the same with a full size hi-torque factory starter on the other side.
They aren't equal length though, if you get all worked up about that fact.
Equal length, no, not when I would like to run my new Dorman 2.5" ramshorns!!
He, He!!
But they won't fit my chassis.
And, thanks Malvn for the Shoenfeld header link.
He, He!!
There are other ramshorn like with the outlet in different places for the drivers side
I have the 2 1/2 in my 69 pickup
All angle plug heads are not equal. I had 034 Bowties in my mid 70s X body. I put on a pair of Brodix Track 1 heads, and the headers would no longer fit. I wanted to upgrade to 1 3/4" primary tubes and the search got real small. The only thing under $600 that the manufacturer would guarantee to work were Schoenfeld. But after installing them, I discovered that most of their products are geared towards dirt/off road racing. They tuck so tight up against the frame I have to run a 4 1/2" long oil filter and remove the header to change it. My next set of heads will not be angle plug.
