Anyone using these in a hyd roller bbc ? A friend of mine just bought them, and plans to run them in a 6000rpm max marine engine. Mild hyd roller cam setup. Never heard much about these lifters.
http://www.compperformancegroupstores.c ... hortTravel
BBC comp short travel lifters
Re: BBC comp short travel lifters
Better figure out how to restrict the oil that comes out of them.WBR33 wrote:Anyone using these in a hyd roller bbc ? A friend of mine just bought them, and plans to run them in a 6000rpm max marine engine. Mild hyd roller cam setup. Never heard much about these lifters.
I'm not following?vortecpro wrote:Better figure out how to restrict the oil that comes out of them.WBR33 wrote:Anyone using these in a hyd roller bbc ? A friend of mine just bought them, and plans to run them in a 6000rpm max marine engine. Mild hyd roller cam setup. Never heard much about these lifters.
I have used the Comp "short travel" competition lifters in a small block engine with no trouble at all however, they use a different manufacturer for those than for their regular hydraulic roller lifters which I have had nothing but problems when attempting to use them.WBR33 wrote:Anyone using these in a hyd roller bbc ? A friend of mine just bought them, and plans to run them in a 6000rpm max marine engine. Mild hyd roller cam setup. Never heard much about these lifters.
