Callie's cranks question
I have a Callie's magnum sbc crank here (brand new) and the dampener bolt hole is counterbored 2.150 deep to .470dia then the last 1.400 is tapped 7/16-20.
Have I possibly received a blem crank.
1st time I've seen something like this in a high dollar crank.
results speak for themselves
Re: Callie's cranks question
Callies cranks all need an extra long balancer bolt. Not sure why they do it that way but the Callies cranks I've seen are all like that.
Rick
Rick
That's the way they were made, not sure if they're still the same though! I refuse to use any Callies products here, we do sell their products when customers call though.
I've only worked with a handful of their cranks and most were BBC's. It was a few years ago on a SBC, I called complaining about that issue you see. All I can say is I wasn't a "happy camper" about it!
Thanks, Gary in N.Y.
P.S. Wait till you get up to needing to use a "balancer-remover/installer", all I'll say is "Good Luck"!
Sept. 2019 - Drag-Week Winner - New York Street Ride 7.23+ @ 196+ @ 3800#+
I wonder if the thought was to reduce the stress concentration at the bottom of the thread by moving it deeper, all the way into the main bearing journal?
Callies been doing that for years.
You need to pick one of these kits.
http://www.callies.com/components/specialty/
Call and talk to Don G at callies.
He'll make sure you get the right one.
Yep, just about everyone does it.MadBill wrote:I wonder if the thought was to reduce the stress concentration at the bottom of the thread by moving it deeper, all the way into the main bearing journal?
Years back when following the discussion on Nissan KA24 snout failures this was the fix.Warp Speed wrote:Yep, just about everyone does it.
It adds the strength of the bolt to the snout.
It reduces breakage at the blend between the snout and the gear stop.
- needforspeed66gt
This.SchmidtMotorWorks wrote:It adds the strength of the bolt to the snout.
We used Callies cranks exclusively in our GTA race engine program years ago, always used a nice long ARP stud threaded into the crank to hold on the damper, pulley, and dry sump cog drive. It's a stronger design that is used in the current LS crankshafts, NOT a reason to avoid their cranks.
Nate @steeldustmachine
Engine Machinist
Engine Machinist
You would be better to use the fastener that goes into the crank to hold the damper, and face mount the accessories to the damper, than running the long fastener to hold everything.needforspeed66gt wrote:This.SchmidtMotorWorks wrote:It adds the strength of the bolt to the snout.
Just a little tangent! Lol
