There seems to be at least two different issues that may or may not be related (distortion of a block under load and power loss from prior distortion due to main bore misalignment). An initial pertinent question is whether the engine tested had pre-existing main bore misalignment.David Vizard wrote: First block distortion. Our measurement system was always plagued by vibrations so we had to do quite a few tests then, by averaging out results, come up with a number. Unfortunately the accuracy of this was always questionable but it was better than 'no idea what-so-ever'. On our Cosworth block the twist at 270 hp and 7000 rpm was tested five times over three consecutive days. Answers, going up the scale of the measured twist were, - .0045, . 0077, .008, .0082, .0126. Any one of those numbers could have been right or wrong but they were at least numbers we could re-produce in a static test. With the block mounted on a giant pre WWII horizontal mill we put the seen twists into a long block assembly less crank. With dial gauges measuring the mains defection we saw up to 0.004 out of alignment from front to back to center main.
The question is what would this be worth if we were to fix it? If it was that much what is the point in worrying about the mains alignment down to the last tenth of a thou when its on the engine stand.
Aside: I finally found Bill's (bill@bhj) post from 2010 viewtopic.php?f=15&t=22589
I mention it because it is another possible confound whether at 7000 rpms the YB has resonance of any sort with the rotating assembly.I can only partly answer the question -
While testing OEM crank dampers on an inline 6, (292 Chevy) we used to make a quick sweep across the rpm range to spot the general pattern of where the torsion peaks were, then go back and go very slowly across the rpm band where the worst peaks were to get a more exact reading of where those peaks were. We wanted the frequency of those peaks for fine tuning the damper. Inline's are not alone here, I just use it as an example - They usually had several nice peaks to contend with.
If we would set the engine directly on a high peak, (say .6° p-p) we would see that peak slowly rise (~20-30%) and see a corresponding rise in the oil temperature ( say 20-30°) Since the engine owner didn't want to pursue this any longer than necessary, we never sat there to see how high either value would go.
All it proved was that the torsion was enough to make each of the bearings into a small viscous damper which would absorb some energy at the expense of heating the oil in the bearings and consequently in the pan. ...
