Ported Ford 289 heads with port energy discussion
Carnut1
Re: Ported Ford 289 heads with port energy discussion
Post by Carnut1 » Sat Jul 22, 2017 8:44 pm
Port energy graph. After looking at this graph I almost changed my mind but I will stay with my first bet E7's will win small cam and 289's will win large cam by a small margin. Only from the better exhaust flow and higher compression chamber. Guys that hate low lift flow should really like the 289's they really get crankin (by sound) after. 4" lift. Thanks Charlie
Carnut1
Post by Carnut1 » Sun Jul 23, 2017 10:52 am
Always interesting spraying high pressure water into a port. Snapped this before yesterdays flow tests and graphs. Input welcome on chamber shape and water flow. Thanks, Charlie
CGT
Post by CGT » Sun Jul 23, 2017 11:59 am
Id take some jet out of it
Carnut1
Post by Carnut1 » Sun Jul 23, 2017 12:57 pm
More port energy would help!
Carnut1
Post by Carnut1 » Sun Jul 23, 2017 1:38 pm
I did not change the bowl shape much on the Cnc head and with a slightly smaller bowl it easily cleaned my exhaust ports clock except at very high lift. I feel a learning moment coming on.
BILL-C
Post by BILL-C » Sun Jul 23, 2017 2:06 pm
Ever try hose test with a valve secured at a variety of lifts?
Carlquist Competition Engines
Carnut1
Post by Carnut1 » Sun Jul 23, 2017 2:29 pm
BILL-C wrote:Ever try hose test with a valve secured at a variety of lifts?
Hose test?
Carnut1
Post by Carnut1 » Sun Jul 23, 2017 3:51 pm
Carnut1 wrote:I did not change the bowl shape much on the Cnc head and with a slightly smaller bowl it easily cleaned my exhaust ports clock except at very high lift. I feel a learning moment coming on.
Seems the valve job was a bit small and I did a cheap job polishing the ssr. Back to the bench.
Carnut1
Post by Carnut1 » Sun Jul 23, 2017 6:20 pm
cnc head as tested
BILL-C
Post by BILL-C » Sun Jul 23, 2017 7:24 pm
Hose test?
Squirt the hose down the port with a valve locked at .500 lift.
Carnut1
Post by Carnut1 » Sun Jul 23, 2017 7:37 pm
BILL-C wrote:
Hose test?
I was thinking of that but I didn't do that. Packed for shipping. What do you think would happen?
BILL-C
Post by BILL-C » Sun Jul 23, 2017 8:03 pm
We spend 99% of our time looking at the ports without a valve in place while doing the port work. It's really easy to lose perspective. That water flow pattern would have looked alot different with a valve in place. It would have been a "flatter " pattern.
Warp Speed
Post by Warp Speed » Mon Jul 24, 2017 7:19 am
And the pattern will change big time as the location/angle of attack of the water hose.
We are learning what here?!?
randy331
Post by randy331 » Mon Jul 24, 2017 7:42 am
Warp Speed wrote:And the pattern will change big time as the location/angle of attack of the water hose.
How clean our port was ??
mag2555
Post by mag2555 » Mon Jul 24, 2017 7:51 am
I am not troubled with dead on valve seat concentricity any more at room temps as things shift around a good bit. ( and this is a good reason for guide clearance a tad over what you would want !) once a head is up at full throttle running temp with one side of the Intake valve seat at near Exh temps and the other side only 200 degrees above coolant temp, and on Aluminum heads with interlocking seats it can be far worse!
Sorry, I did not mean to change subjects on you Charlie!
