hard seats in green diamond engine
machinedave
Post by machinedave »
Has anyone installed new exhaust seats in a 1948 green diamond flathead 6 cylinder engine? Or perhaps I should ask has anyone cut into water installing them?
mag2555
Re: hard seats in green diamond engine
Post by mag2555 »
No access to having the bowls sonic tested?
DaveMcLain
Post by DaveMcLain »
Why does it need to have hardened seats?
machinedave
mag2555 wrote:No access to having the bowls sonic tested?
I do not have access to a sonic tester.
machinedave
DaveMcLain wrote:Why does it need to have hardened seats?
The seats have severe pitting. I can make bigger valves if I have to but would rather install new seats if I can do it without finding water.
mag2555
Post by mag2555 »
I would have to think that you have the needed .200" of depth to work with, and this amount of depth holds up with racing spring pressure so tractor spring should be cake!
Goodson supply sells a product for sealing cracks in heads and using during seat installs where water jacket issues may take place.
Racerrick
Post by Racerrick »
Buy one off ebay, they work excellent
wyrmrider
Post by wyrmrider »
what are the valve sizes and length in those dave
exhausts sodium cooled or inconel or ???
and
have you asked durabond
machinedave
wyrmrider wrote:what are the valve sizes and length in those dave
and
1.440" head, 5.560" length, .3715" stem. I don't believe they are sodium or iconel
mag2555
Post by mag2555 »
So the Intake seats can be re- cut and work out?
machinedave
mag2555
Post by mag2555 »
Let me guess, finding a better block is like Hens teeth?
wyrmrider
Post by wyrmrider »
that's what I remembered really long valves
exhausts paired next to each other
you would think that that vintage casting would be thick enough but get a sonic tester and find out
most of my flathead experience was ford and Chrysler
wonder why the intakes and not the exhausts>
best to also check the cam on a cam doc and maybe update camgrind and springs
statsystems
Post by statsystems »
I have most of my experience with ford and Chrysler stuff too, with a healthy dose of Continental mixed in and I put hard seats in most of them.
But the green diamond deal IDK. I'd be scared without a sonic check. I'm a bit of a chicken though.
DaveMcLain
What does it look like if you hit it with a stone without doing anything else? Looking at the picture I think it might not be as bad as it appears once you knock off the rust that's sticking up from the surface of the existing seat.
