Budget pulling truck engine named (Tommy Boy)
CGT
Re: Budget pulling truck engine named (Tommy Boy)
Post by CGT »
randy331 wrote: Fri Nov 17, 2017 11:44 pm
CGT wrote: Fri Nov 17, 2017 11:31 pm More area at and around bdc. Lift could potentially make the valvetrain more stable depending on a bunch of things lol. Dont be scared lol
So you don't like the REV lobe now ?
I need more lift ?
No I like the Rev lobe, I may just be a lift junky. :D I guess you have to draw the line somewhere was just wondering to myself if that taller lobe may be more dynamically stable that's all.
PFC1
Post by PFC1 »
Why are you looking for horsepower peak so low?
Bret
Pullin' for Christ
randy331
Post by randy331 »
PFC1 wrote: Sun Nov 26, 2017 5:16 pm Why are you looking for horsepower peak so low?
Bret
I'll take a peak as high as I can get, but at 420 cube and low port 23* heads, I'm just being realistic within those confines.
PFC1
Post by PFC1 »
FYI, in Central and Southern MO the competitive SS big blocks horsepower peak in mid 7s and higher with OEM iron intakes, Fords generally a little higher than Chevy. Our ProStreet's peak from 8200-8500 with OEM heads and cast aluminum intakes.
I know IAMO allows only OEM blocks in big blocks so that makes the Pro Street a little harder to find that higher peak with big blocks. But I'm thinking to run the small block competitively you'd have to turn the snot out of it.
As for a competitive small block in this class I'd have little advise, we just don't do them down here.
Bret
Pullin' for Christ
randy331
Post by randy331 »
Well I'm not as concerned about it making peak at a given rpm as much as hanging on well past peak good.
The 355 ( Tommy Boy ) peaked at 7300-7400 rpm, but went down the track much higher than that.
New engine will start out with a 9000 rev limit till we sort gears out for it.
If this combo works out well and he wants to keep pullin that class we'll go 14* heads.
I'm doing a big block for a different truck too, different class, so we'll see how it does.
steve316
Post by steve316 »
With 427 ci. peak torq. 6000 peak hp 7100. I don't think it was cam's fault it didn't peak higher with the 1720 lobe 1960 lobe.
