copper radiator vs aluminium engine
Paul Rig
Post by Paul Rig » Sat Jan 07, 2017 9:33 am
Im a bit worried I am making a very good battery out of some very expensive parts.
How would I correct a corrosion problem between copper and aluminium (yes I can spell :D )
Could I connect them on the same ground plane to stop this or isolate the radiator.
Paul
Belgian1979
Re: copper radiator vs aluminium engine
Post by Belgian1979 » Sat Jan 07, 2017 9:41 am
Well, we spell aluminium the way you do.
Anyway, put in a zinc sacrificial anode in the plug of your radiator and you should be fine.
Paul Rig
Post by Paul Rig » Sat Jan 07, 2017 10:57 am
good idea but zinc tends to leave messy green grease like goop in closed loop systems.
Altho I might have seen it used in diesel cooling system on a Cummings, contained in a oil filter type housing where it conditions the water.
Kevin Johnson
Post by Kevin Johnson » Sat Jan 07, 2017 11:16 am
Paul Rig wrote:Im a bit worried I am making a very good battery out of some very expensive parts.
Paul
It is just that the Yanks are well-versed in history and agreed with that Brit, Davy.
Davy settled on aluminum by the time he published his 1812 book Chemical Philosophy: "This substance appears to contain a peculiar metal, but as yet Aluminum has not been obtained in a perfectly free state, though alloys of it with other metalline substances have been procured sufficiently distinct to indicate the probable nature of alumina."[89] But the same year, an anonymous contributor to the Quarterly Review, a British political-literary journal, in a review of Davy's book, objected to aluminum and proposed the name aluminium, "for so we shall take the liberty of writing the word, in preference to aluminum, which has a less classical sound."[90]
roc
Post by roc » Sat Jan 07, 2017 11:17 am
Paul Rig wrote:good idea but zinc tends to leave messy green grease like goop in closed loop systems.
You're referring to the Fleetguard DC4A coolant filter.
PS.: You sure can spell aluminium, but not Cummins! :lol:
Kevin Johnson
Post by Kevin Johnson » Sat Jan 07, 2017 11:20 am
Should we distinguish between people running straight water and those using a commercial product that should already address this problem?
Aside: remember that dyes will persist longer than pH balancing compounds. Change the fluid regularly.
Paul Rig
Post by Paul Rig » Sat Jan 07, 2017 11:34 am
roc wrote: You're referring to the Fleetguard DC4A coolant filter.
Dam it spell checker screwed me =D> LoL
that does sound like the filter I use to replace.
I was always told to fill with straight water on that particular truck.
Cummins tripple5 bloody little ripper of a v8 diesel
dfarr67
Post by dfarr67 » Sat Jan 07, 2017 12:47 pm
Evans coolant?
roc
Post by roc » Sat Jan 07, 2017 1:03 pm
The Cummins triple-nickel is back! Cummins 5.0L V8 Turbo Diesel – Powering the Nissan TITAN XD
Totally different engine though.
swampbuggy
Post by swampbuggy » Sat Jan 07, 2017 1:50 pm
I saw an article in a hot rod type of magazine that featured a Pro-Stock styled pickup truck with a turbo charged Duramaxxxxx i believe it was and that thing was some where i believe in the low 8 sec. range. :shock:
Belgian1979
Post by Belgian1979 » Sat Jan 07, 2017 4:42 pm
acidity and presence of O2 in the system are a contributing factor.
joe 90
Post by joe 90 » Sat Jan 07, 2017 6:09 pm
Antifreeze.
The Radius Kid
Post by The Radius Kid » Sat Jan 07, 2017 7:48 pm
4sfed
Post by 4sfed » Sun Jan 08, 2017 3:01 pm
The Radius Kid wrote:http://www.rmi25.com/tech-specs
When I bought a radiator from Ron Davis, it came with installation instructions similar to the link posted by Radius Kid . . . except he recommended checking DC and AC voltage and recommended 0.3v as safe for an iron engine and 0.15v for aluminum. Test ALL electrical components including the starter.
crazyman
Post by crazyman » Mon Jan 09, 2017 1:03 am
I would say a common ground between the components couldn't hurt anything..
