Just thought I would do some digging...
"This was our very first weird test of the series. Most people would never think of installing a stud girdle on such a mild engine, but we're not most people. In last month's tests we witnessed the 3/8-inch screw-in studs in the heads flexing as we lashed the valves. The flexing was visible to the naked eye, so we hypothesized that it might kill some lift and duration. In an attempt to prove our hypothesis correct, we installed a COMP Cams stud girdle, which ties all the rocker arm studs together adding tremendous rigidity. It didn't help.
Power and torque actually fell off at most rpm. We can't explain why, but the results speak for themselves. The stud girdle will come off next month."
CAM..COMP Cams XE256H cam (256/268 adv duration, 212/218 duration @ .050, .447/.454 valve lift, 110 lobe separation.
Scroll down to article section 8!
http://www.superchevy.com/how-to/engine ... art-three/
