Ported Dart pro 1 pre platinum
gnicholson
Re: Ported Dart pro 1 pre platinum
Post by gnicholson » Wed Feb 01, 2017 7:43 pm
this thread is rapidly turning into a book. i have some dart 210 cc heads the same vintage that i worked 10 years ago that flowed about 290 on the intake .thinking about going back through them with some info from here. lots to digest
Carnut1
Post by Carnut1 » Wed Feb 01, 2017 7:57 pm
gnicholson wrote:this thread is rapidly turning into a book. i have some dart 210 cc heads the same vintage that i worked 10 years ago that flowed about 290 on the intake .thinking about going back through them with some info from here. lots to digest
Chapter 2 coming up!
randy331
Post by randy331 » Wed Feb 01, 2017 8:50 pm
I've seen 290cfm beat 315cfm on the dyno.
Be careful what you digest.
Biteme
Post by Biteme » Wed Feb 01, 2017 9:08 pm
* is that 23* head a dart? If so that's a lot of material that's been removed from the ssr.
I would've thought there'd be water in there....
user-9274568
Post by user-9274568 » Wed Feb 01, 2017 9:23 pm
Biteme wrote:* is that 23* head a dart? If so that's a lot of material that's been removed from the ssr.
Pro-Filer
Carnut1
Post by Carnut1 » Thu Feb 02, 2017 8:58 am
A quick look on Stan's site and these heads are real close to what some pros produce. Thanks, Charlie
groberts101
Post by groberts101 » Thu Feb 02, 2017 10:35 am
Which is great news when comparing static airflow numbers. Shows that you did a good job pushing the boundaries. =D>
But I believe the better question should be.. were their pitot's reading the same exact airspeeds around the short turn as your port/s? Maybe just call Ron's and ask if they have any other data or notes on those heads?
groberts101
Post by groberts101 » Thu Feb 02, 2017 10:48 am
* wrote:The first photo is a 23 degree, the second photo is my 13 degree.
Thanks for the replies *.
So, to my partially trained eyes it looks like the floor on the steeper valve angle heads is biased towards the center of the cylinder more so than the lower angle heads. This seems to be the trend in the aftermarket and although the layback angles are a bit different(asymetrical).. my 8° Kasse heads have very little apex bias towards the floors short inside corner.
Is that purely a result of valve angle reductions affect on straightening and slightly lengthening the throat section?
David Vizard
Post by David Vizard » Thu Feb 02, 2017 11:14 am
Nice work on those SBC ports with the 'speed bump'. Any chance I can get all the figures to run through my soon to be published flow bench program??
DV
user-9274568
Post by user-9274568 » Thu Feb 02, 2017 11:16 am
David Vizard wrote:*,
DV
What do you need?
user-9274568
Post by user-9274568 » Thu Feb 02, 2017 11:19 am
23º DATA
2.98in² MIN (throat)
67cc chamber*
1.390 x 2.400 opening
Mr Gasket 5824**
2.99in² AVG CSA
5.40 port length
265cc runner
2.140/5.255/.065 margin/.290 tipº
1.580/5.240/.080 margin/.290 tipº
50º intake seats
radius 45º exhaust seats
4.155 fixture
1.875 pipe
.200 138/114
.300 210/154
.400 257/191
.500 299/218
.600 326/235
.700 344/248
.800 352/252
.900 358/254
1.00 363/256
13º DATA
3.08in² MIN (throat)
42cc chamber
1.500 x 2.280 opening
3.12in² AVG CSA
6.155 port length
300cc runner
2.180-2.220 valve
1.580-1.600 exhaust
50º seats
4.155 fixture
.200 150/94
.300 227/135
.400 294/195
.500 349/224
.600 386/247
.700 403/261
.800 410/274
.900 414/281
1.00 418/287
David Vizard
Post by David Vizard » Thu Feb 02, 2017 4:36 pm
*, I hate to be a pain here but, just for the 23 degree head, I need the flow figs at 0.50,0.100, 0.150, 0.250,and 0.350 for all the trend and number crunching.
Also, for 23 degree head I need center line length of an intake and an exhaust port. With that I should be good to go.
Thanks
DV
Carnut1
Post by Carnut1 » Sat Feb 04, 2017 7:14 pm
first vs. Last flow test. This had the Slight backcut Manley valves and tulip exhaust valves
Carnut1
Post by Carnut1 » Sat Feb 04, 2017 7:15 pm
flow per sq in graph.
Carnut1
Post by Carnut1 » Sat Feb 04, 2017 7:29 pm
Port energy as cast vs. ported. This is compairing a 203cc intake against a 248cc intake. 1204 intake size vs. 1206 intake size, 77cc exhaust port to a 91cc exhaust port. Not a stellar victory but a good try. I believe these are still capable of our 700 hp target. Interesting program that really helps aim the porter in the right direction. If D.V. finalized the port energy section a bit sooner you can bet I would most likely made these a bit smaller. I am still quit happy but not fully satisfied with the results and would like to give special thanks to D.V., groberts, Randy331, CGT, *, Eric, and many others who helped on these. Charlie
