Ported Dart pro 1 pre platinum
Carnut1
Re: Ported Dart pro 1 pre platinum
Post by Carnut1 » Tue Jan 10, 2017 4:32 pm
center of cylinder side
Carnut1
Post by Carnut1 » Tue Jan 10, 2017 4:39 pm
Chamber / ssr notice ssr bias.
Carnut1
Post by Carnut1 » Tue Jan 10, 2017 4:40 pm
Flange view
Carnut1
Post by Carnut1 » Tue Jan 10, 2017 4:41 pm
Port fit with 1 7/8" pipe.
Carnut1
Post by Carnut1 » Tue Jan 10, 2017 4:42 pm
View of widened ssr
groberts101
Post by groberts101 » Tue Jan 10, 2017 6:35 pm
Carnut1 wrote:
View of widened ssr
Charlie, I see a wider floor and short turn overall.. but IMO you didn't break the floors corners soon enough. Too much straight section after the minor choke point. That's what I was pointing at with the "assymetrical throat" comments. The corners start VERY subtle at the bottom of the seat and start to lay back from there. Start forming the corners of the floor from the bottom of the seat and make it more pronounced to blend into the floors corners. Either side, not too much center, of the apex gets layed back towards the seat.. like small spillways to help gas navigate the turn. I'm tight on time right now but this was a quick grab of one of Chad's exhaust ports.
Hard to see in the pic but even still.. notice Chads corner layback, his whole short turn really, starts considerably earlier than it looks like your port does. Well.. at least from the perspective I can see. One of the reasons I wanted a good shot straight and up into the bowl from the combustion chamber side. Another dead straight down into the bowl for better seeing choke shape would help us determine how you have the choke/short side formed.
PS. won;t be till later but I will snap some pic's of a few heads I have laying around here that will point out the shape I'm getting at here. One's a little d-ported Vortec head that takes a 1.625" OD 16 gauge match formed pipe that flowed 247'ish @.700". 1.54" valve size. Might have been 243 cfm.. have to find my flow sheets to be sure. Hardly did any major work to it.. well, blew the cealing out around the guide and thinned it pretty substantially.. but mostly floor widening and SSR work to settle the floor speeds down was all that it took.
groberts101
Post by groberts101 » Wed Jan 11, 2017 5:00 pm
How's it going today, Charlie? Any more updates on this project?
Buried in snow here lately but I can still dig some heads out if you want. I remembered that I scrapped out my old LT1 heads. That one had a nice D-port exhaust design too(240'ish cfm@.700 with over 500 horses from a typical medium size cammed 350) but the intake ports had been puttied up so excessively from all of those sudden water passage intrusions. Probably also one of the most extreme short side laybacks on any head I've ever done too. It kept responding, so I kept cutting. #-o
Carnut1
Post by Carnut1 » Wed Jan 11, 2017 6:09 pm
groberts101 wrote:How's it going today, Charlie? Any more updates on this project?
Took a step back and started a new port. I want to get an idea what gains you get from each part of the port. Don't dig out anything for me. You have been a great help so far. Some interesting stuff coming I hope. Thanks, Charlie
Carnut1
Post by Carnut1 » Wed Jan 11, 2017 7:12 pm
Port #8 stock 2.08/1.6 combo
Carnut1
Post by Carnut1 » Wed Jan 11, 2017 7:13 pm
Port#8 stock flows
Carnut1
Post by Carnut1 » Wed Jan 11, 2017 7:42 pm
Port #8 gasket match to 1205 and open pinch. This pic shows bowl work for next test.
Carnut1
Post by Carnut1 » Wed Jan 11, 2017 7:43 pm
Port #8 exhaust radius exit shape.
Carnut1
Post by Carnut1 » Wed Jan 11, 2017 7:51 pm
Port #8 gasket match open pinch and radius exhaust exit flows. I am surprised at 18.6cfm intake increase @.5" lift and 10 cfm exhaust increase at .5" lift. About 25 min porting time.
Carnut1
Post by Carnut1 » Wed Jan 11, 2017 8:27 pm
Stock bowl
Carnut1
Post by Carnut1 » Wed Jan 11, 2017 8:28 pm
Deep bowl cut, about 15 min.
