wyrmrider wrote:let us know statsystems
on those steep seat builds I'm curious
if you went to an IR with say 8 degrees less seat timing and about the same at 200
or
same seat timing and fatter at 200 (would the steep seat still be able to kill the reversion)
or
split the difference and try a 4 degree shorter seat to seat cam
the "wheelbarrow of cams approach"
or
methodology would be to plot the intake opening to see where the reversion starts (lift and degree wheel) then grind the cam to the max to match
an approximation would be to take the head flows and simulate
Randy is on to something and I appreciate his sharing as much as he does.
I would think that mike's computer program would cut down the number of cams in the wheelbarrow
I'm just putting the carb together now, so I plan on beating the hell out of it soon.
I'm not sure I have ever seen a SFT cam with an IR but I may be wrong.
Mike, can you do an IR for a SFT cam?
