2 heads better than 1 - power porting E7TE iron.
jcisworthy
Re: 2 heads better than 1 - power porting E7TE iron.
Post by jcisworthy » Wed Sep 13, 2017 8:48 pm
David,
Thank you for giving me the opportunity to get in the competition. Also, thank you for the time it took you to come up with your analysis, I really value and appreciate your feedback.
"Discouragement drains our spirits; perseverance accomplishes the job"
David Jeremiah
https://rbjracing1.wixsite.com/website
Phone 518-915-3203
David Vizard
Post by David Vizard » Thu Sep 14, 2017 10:30 am
jcisworthy wrote:David,
John,
you are more than welcome.
DV
David Vizard
Post by David Vizard » Thu Sep 14, 2017 2:27 pm
I have asked this before and missplaced the info. Can anyone tell me the most cost effective spring for the modded E7TE head test for the heads Charlie and I collabarated on. Needs to go about 6200 with good control and accomadate 0.52 lift.
thanks
DV
Carnut1
Post by Carnut1 » Thu Sep 14, 2017 4:14 pm
David Vizard wrote:I have asked this before and missplaced the info. Can anyone tell me the most cost effective spring for the modded E7TE head test for the heads Charlie and I collabarated on. Needs to go about 6200 with good control and accomadate 0.52 lift.
thanks
DV
Hydraulic roller cam?
David Vizard
Post by David Vizard » Thu Sep 14, 2017 4:16 pm
thanks
DV
Sorry Charlie - should have said. Answer - yes.
DV
travis
Post by travis » Thu Sep 14, 2017 4:25 pm
thanks
DV
What is the installed height?
Carnut1
Post by Carnut1 » Thu Sep 14, 2017 4:35 pm
http://www.jegs.com/i/COMP-Cams/249/986-16/10002/-1 These are about as soft as I would try.
powerhouse
Post by powerhouse » Thu Sep 14, 2017 7:39 pm
Trick flow makes a decent relatively inexpensive kit for the E7 heads. Includes springs, retainers,keepers,seals and shims.
Powerhouse Performance Machine
Andrew Jeffery
508-328-9884
turbo2256b
Post by turbo2256b » Thu Sep 14, 2017 9:38 pm
Used behive springs on mine with titanium retainers works well with a mild hyd roller set up.
David Vizard
Post by David Vizard » Mon Sep 18, 2017 7:02 pm
turbo2256b wrote:Used behive springs on mine with titanium retainers works well with a mild hyd roller set up.
Yes Turbo - good combo. Have used the similar on some 302's a few years back. Made the Ti retainers out of some old cup car ones.
The Comp 26918 springs and the Ti retainer combo with a solid, not too aggresive road race spec roller cam, was good to over 8000 rpm.
DV
turbo2256b
Post by turbo2256b » Mon Sep 18, 2017 10:04 pm
DV
Was using Crane behive springs for E7 heads with their stock length vales. since the heads were set up with the taller 1.9/1.6 had to pitch their retainers. A stroke of luck at a auto shop near by found a Moroso Ti retainer that fit well after removing sharp edges of the spring ends. Was running dual springs steel retainers only could hit about 6400 give or take and would float the valves. After installing the behives started at 6400 shift first to second went up in 200 rpm shift points finally ended at 7200 made the shift and blew pieces of gears out the back cover of the rear end. In front of the local Ford dealer no less. The engine was still pulling hard that was 3 or 4 years ago just installed a new rear I assembled just finished the break in, soon will see what breaks next.
David Vizard
Post by David Vizard » Tue Sep 19, 2017 3:30 pm
DV
Ahhh -the fun and adventures of motorsport. Thanks for the info turbo - it gives me just a little more insight as to what these springs can do.
DV
Walter R. Malik
Post by Walter R. Malik » Tue Sep 19, 2017 7:34 pm
DV
David ... you need to give ALL the information as O.E.M. production E7 heads have a different installed height on the intake side vs. the exhaust side and the stock valve lock groove height is different on the intake and exhaust sides.
Ford Racing offers an inexpensive moly retainer kit, M-6514-B50, with 8 retainers of one depth and 8 retainers of another depth so the same installed height on the intake side and exhaust side is achieved, (about 1.800").
This is not usually an issue when aftermarket valves are used.
There are bunches of valve springs to fit that scenario on that head ... we use Lunati #73815.
turbo2256b
Post by turbo2256b » Tue Sep 19, 2017 7:50 pm
Walter R. Malik wrote:
DV
That can depend on valves are used. ert%r -- my cats comment. installed height ended up around 1.822 I and E in my case
David Vizard
Post by David Vizard » Wed Sep 20, 2017 11:35 am
DV
Walter,
Even with 3 decades of SBF expeience under my belt I did not realize this. It is definitly going into the book. I guess as such it should be mentioned in both the head and valve train chapter.
Thanks,
DV
