2 heads better than 1 - power porting E7TE iron.
Re: 2 heads better than 1 - power porting E7TE iron.
First D.V. intake port copied. Without the chamber work is 8 cfm below D.V.'s port on my bench. My bench seems to read cfm shy on the top end but the same as D.V.'s at the low end. We are using different benches, bore adapters, clay radiuses, and different valves and valve openers. My bench also has the swirl meter all of these make a difference. I will work hard at not making these sprinklers. Thanks, Charlie
Port looks really good...how is the short turn versus stock?
Radical,
D.V. copied chamber. Very interesting mods. I can see the logic behind them. Thanks, Charlie
Someone recently asked about min thickness. That is about as far as I like to push it. By final shaping it may be as low as .075". That is just into water no exhaust port next to it. D.V. E7TE copied ports. Thanks, Charlie
D.V. serdi v.j. 2.0" diameter. Notice how much metal the serdi removed, I was under the impression that E7TE heads were thin castings but I was wrong. The intake bowls are quite thick. Thanks, Charlie
Partially finished bowl. Lots of metal removal needed and close sonic checking.
Serious serdi exhaust cut. Ssr before view.
Over the years I have had a lot of customers who wish to only install the 1.900" intake and 1.540" exhaust valve and simply do the appropriate valve bowl porting on the E7TE heads.
It would be great to know just how much improvement this got them with their "1 up" RV type camshaft, as they just wouldn't go for complete porting.
I have never had one of these warmed over street engines on the dyno to see that kind of Wide Open Throttle comparison.
While my experience is not as extensive as you guys, I have been a Ford guy most of my life and worked on several of the most popular SBF castings. Still interested in doing an angle mill on a set of the E6SE "heart chamber" heads Walter has mentioned using many times for dirt track motors. Unfortunately my hands just can't take the abuse of heavily ported iron for many more years so I doubt I'll ever go there with all the nicer new/used aluminum stuff floating around these days.
As I've mentioned over on your other threads Charlie, is that the short side thickness is THE largest determining factor for what the "best valve size" is. I've seen MANY guys stuff 2.02" valves in these heads and the final port shape(specifically the SSR) suffers heavily compared to a 1.90" valve. IMHO, with today's cam and valvespring/valvetrain technology there is absolutely no reason to push beyond about a 1.94" valve size on most any of Ford's little 302 heads. Better to have short turns that can handle bigger duration/higher lift cams than the other way around. Airflow quantity is great is you're already severely restricted, but flow quality and wider power curves seem to rule with most applications that I see and work on.
Plus, how much peak airflow does a cylinder head need to meet the demand for most sub-7000 rpm SBF street motors? A heavily well ported E7 casting with 1.90" valves cannot supply that demand? More peak airflow is ALWAYS better on a running engine?
BTW, I used to "cheat airflow" by lopping down guides too. Always.. and I mean ALWAYS resulted in increased valve guide wear/increased oiling of the ports. And no matter the positive seals installed it could never be completely controlled or stopped. Sometimes that extra bit of flow/power becomes useless if it doesn't last as long and the chambers start dirtying up.
In the 90's I would mill out the whole guide and use k-line guides and never had an issue. K-lines are tough and just do not wear if the clearances are set correctly. David decided to do the nearly impossible to copy milled down, slightly curved and biased guide boss. Thanks, Charlie
Walter, I had one D.V. intake bowl copied but did not get to complete the pinch, ssr, port and chamber. Basically the left half of the page is my first D.V. copied port and chamber with bench #s , subtracted leakage bench #s and swirl. The D.V. valve job, oversized valve and specific angles with bowl work are a huge step above stock but still 20 cfm below full dressed port and chamber. Thanks, CharlieWalter R. Malik wrote:Over the years I have had a lot of customers who wish to only install the 1.900" intake and 1.540" exhaust valve and simply do the appropriate valve bowl porting on the E7TE heads.
I was interested in knowing the amount of torque or horsepower improvement of simply increasing valve size with minimal port work over completely as produced stock heads ... airflow improvements are really not the question I was looking to get answered.Carnut1 wrote:Walter R. Malik wrote:Over the years I have had a lot of customers who wish to only install the 1.900" intake and 1.540" exhaust valve and simply do the appropriate valve bowl porting on the E7TE heads.
Thanks anyway ...
I know Walter, I figured I would show what I can. D.V. will be doing the dyno work. Thanks, CharlieWalter R. Malik wrote:I was interested in the amount of torque or horsepower improvement of simply increasing valve size with minimal port work over completely as produced stock heads ... airflow improvements are really not the question I was looking to get answered.Carnut1 wrote:Walter R. Malik wrote:Over the years I have had a lot of customers who wish to only install the 1.900" intake and 1.540" exhaust valve and simply do the appropriate valve bowl porting on the E7TE heads.
Thanks anyway ...
