Bbc main clearance
Re: Bbc main clearance
I was not aware that you could buy -.011main bearings who offers them
one mans magic is another mans engineering--robert heinlein I think I need some magic ,the engineering is not getting through real world testing. quote Jpankey
https://www.summitracing.com/parts/kgb-mb556hp011
ship date 12/19, only 1 unhappy review, but there you go.
Get Smokey Yunick book he say in if you need to tighten up your clearance a little just sand the caps a very little at a time to get less clearance..
https://www.abebooks.com/Smokey-Yunicks ... 472060USED
No way would I run one with over .0035.
Why not simply have the mains ground to .020 ?
Run those main bearing clearances over .0035" and you will probably slowly pound the bearings into end of life condition. JMo
thanks Dan
