Solid Lift Cams w/ high Seat Pressure
Hi guys, I'm new to to forum so if this has been coverd before please try to bear with me. I have heard that the Nascar motors run around 250 lbs of valve seat pressure with a flat tappet cam. Is this true? If so how do they manage to do with with out welding the cam to the lifters? Todd
Todd
I have a friend that works at one of the engine shops for one of the top cup teams and they are running around 160 at the seat and low 400s over the nose you have to remember they are runing EXTREMLY lite components such as small stem valves and the springs they run are super exspensive.
On the other hand we have some engines with the Schubeck lifters and cast cams with 200 at the seat and 490 over the nose so far we have had no problems and we have also been using the tool steel lifters form Andy at Precision Products and have been runing 170 to 180 at the seat and up to 430 over the nose with no problems.
Website is up and running
Machine shop tour
Monthly Specials
Machine shop tour
Monthly Specials
Todd
I've got a Ford block in the shop that came from Roger Penskes shop before they went to the Dodge and the Cam tunnel is all inclosed on this block and the cam is submerged in oil. If you would like some pics of this block email me and I will get some for you.
Machine shop tour
Monthly Specials
Machine shop tour
Monthly Specials
