Pontiac 455 cam recommendation
Re: Pontiac 455 cam recommendation
with the short little valve springs some dwell was necessary if there was any duration
best to step back and look at the flow demand, cylinder heads, compression, etc
then develop timing points-- duration and lca will fll into place
tjs44 wrote:Len,I know they like the 108 for HP but IMO with a street stick shift car they suck to drive.Been there done that.Tom
They would suck with that much duration @.050, way to much overlap for that rpm.tjs44 wrote:With a 250-250 on a 108 with a 3.90 rear gear it did not like being under 1800 rpms around town in 5th gear and had to be pulled back
TJS thats a relatively short duration for a 455 and a 108 will hardly be noticeable. I agree on the street with a 250 250 it would be quite noticeable. Advertised duration is what has the most affect on idle and low speed characteristics and if you compare a RA4 cam to the XE 274 you can see why the XE is more street able , advertised for the RA4 was 308, 320 while the XE274 is only 274, 280. The aggressiveness of the profile makes a big difference in drive ability. An off the shelf XE274 would work fine for this application but a custom grind with a 108 would work even better.
Len C
Len C
I was thinking back to the Winternationals CA 1962?
Micky Thompson had the Tempests with the 421's installed and solid rear ends instead of the transaxle
one of them had heads with the sparkplugs like an FE Ford- I know cuz I changed them
wish I could find the pictures- never saw those heads again
anyone else seen them?
custom grind...would work even better
heads with different flows
tall gears
your best shot
http://jonescams.com/street-performance/
I would think there is more experience with gears and converter, maybe more compression and heads with less exhaust flow
but that's not OP's build
tall gears
your best shot
I would like to comment that this vehicle idles with a slight lope, pulls hard and is all done at 5,400 RPM but, revs to 6,000 RPM easily, pulls out of a city 90 degree turn in third gear, at around a 1,000 RPM with no detonation and driving on the interstate is perfect in 5th.Walter R. Malik wrote:I called an acquaintance who has a very similar combination to yours but, a Tri-power and 480 cubic inches in a mid 70's Firebird with a Tremic and 2.56/1 rear gear.pmd400 wrote:Hi
Iv read plenty of articles, books and forum threads on cams. Iv studied a couple of vizards books, Jim hands Pontiac book as well as several articles and forum threads. Old school Pontiac says to go wide lsa and dual pattern cam. Vizard books tell me tight lsa and single pattern cam. Iv read recently on this forum that lower exhaust lift and less aggressive exhaust lobe is beneficial. So anyway, I'll get to the engine specs
Pontiac 461 - bore 4.18, stroke 4.21
Rods length 6.625
9.4:1 compression
Edelbrock p65 dual quad/dual plane intake
2 edelbrock 600 carbs
1 5/8 diameter/unequal length primary headers
2.5 x pipe exhaust. Mufflers to be used but not yet purchased
6x heads. Flow as follows
Lift Intake Exhaust E/I ratio
.100 76 54 72%
.200 134 117 88%
.300 181 154 85%
.400 219 178 81%
.500 229 194 85%
.600 229 202 88%
Car is a '72 firebird, 3500lbs
Rear is 2.41 or 2.73(have both)
Trans is a Richmond 5 speed, ratios are
1st - 3.28
2nd - 2.13
3rd - 1.57
4th - 1.24
5th - 1.00
Car is a street car. Power brakes are a must. Engine will never go above 5500rpm.
Any recommendations will be much appreciated.
Thanks
He had a camshaft ground by Lunati ...
hydraulic roller ...
single pattern #62009 profile ...
268@.006"; 215@.050"; 134@.200"; .326" lobe lift; 108 separation +2; .538" valve lift with 1.65/1 rockers.
If you are looking for something different, then that's another story.
Excellent reminder Walter
much different than a 4 speed and 390 gears
few have experience with that combo
I think 230 type cams would be no fun at all in HIS build
With that 4.21" stroke, you need some duration.pmd400 wrote:Thanks for the replies. I probably should have mentioned that I'm after a hyd flat cam. Lifter diameter in 0.842. Valves are about .120 longer then stock. Also Iv already got 1.65 rockers
This cam will peak @ 5,100rpm, have plenty of vacuum, and a smooth idle. I would not go any smaller
Cam# P455, H71330-110
228/228 @.050"
.330"/.330" Lobe Lift
.544"/.54" Valve lift w/1.65 rockers
110 LSA
107 ICL
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
Jones Cam Designs
Denver, NC
(704)489-2449
Mike- is that not a mid 280 seat duration flat tappet
I think he is looking for an HR
OP- which is it?
OP- which is it?
Look at his post I quoted. Hydraulic Flat Tappetwyrmrider wrote:Mike- is that not a mid 280 seat duration flat tappet
OP- which is it?
Yes, it's 284 seat duration.
With his stroke, that'll act like a 260 seat duration would in a 350 SBC.
Mike Jones
Jones Cam Designs
Denver, NC
(704)489-2449
Jones Cam Designs
Denver, NC
(704)489-2449
Everybody's attention and priority seems to be with Wide Open Throttle so, I guess that is the only important thing and all that matters here ... have at it.
im not and never have been.I actually drive these engines virtually every day in a stick shift cars and have been trying everything from 108s to 113s and from 218s to 260s Intake for 20 years.Have found wider is better(112)a little bigger(230s)split better(6 more or so on E) have better manners(power brakes),have less detonation issue with 9.5 iron heads on CA 91 gas.Continue on.Tom
Mike you are correct
last post on page 1 he's looking for a HFT
everyone else was suggesting hyd roller except him
I thought that was obvious I don't know why others kept pushing hyd rollerwyrmrider wrote:Mike you are correct
I would think because he does not mention it in first post so people- me included just started making suggestions You have to go back and re read the thread to see the short post at the bottom of the thread
IMHO with that short gear HR would still be a good idea but lots of Pontiacs run FT Hyd- now get the correct ones
