Pontiac 455 cam recommendation
pastry_chef
Re: Pontiac 455 cam recommendation
Post by pastry_chef » Sun Apr 08, 2018 2:28 pm
Some extra info:
OP says with 30 degrees of ignition timing the car will backfire out the exhaust when letting off the gas.
With 36 degrees timing the backfire goes away.
Odd.
Mike R
pmd400
Post by pmd400 » Sun Apr 08, 2018 5:35 pm
Some extra info:
Odd.
That did happen. I had vac advance disconnected. I also had initial set to 6* before tdc to get the total down to 30*. I think it was just a sudden close of the throttle combined with slowing engine speed so it was not getting a lot of advance. If vac advance was connected it wouldn't have happened. Iv had some advice to remove the dual quads and put the iron intake/qjet back on. I'll give that a go this week.
tjs44
Post by tjs44 » Sun Apr 15, 2018 1:26 pm
FYI,The E dual quad is not the best for your pontiac,the Offy is way better.Also your carbs are too small.I do agree that the 30 degree timing is a issue.Tom
mag2555
Post by mag2555 » Mon Apr 16, 2018 6:35 am
You may be backfiring at 30 because your not burning all the fuel and that unburned fuel is then lighting off in the Exh system.
HDBD
Post by HDBD » Fri Apr 20, 2018 8:32 am
Consider oil in the combustion as a possible source of detonation.
