My next 454 build
tenxal
Re: My next 454 build
Post by tenxal »
Bob Hollinshead wrote:Mark, what accumulator are you using? Do you use it for prelube too? Is it controlled with a switch?
FWIW, this weeks National Dragster has a good article by David Reher on wet sump oil control/bearing issues on deceleration (after a pass).
mdabbott2009
Post by mdabbott2009 »
Now how much do you think lighting up the pistons will help? Help with shift recovery or just more power all over?
vortecpro
Post by vortecpro »
mdabbott2009 wrote:Now how much do you think lighting up the pistons will help? Help with shift recovery or just more power all over?
My first thought is the piston is hyp, any weight I can get out is good for reliability, I do wish I would have gone fordged. I believe a foot brake car leaves harder with a lighter rotating assembly, I have goals and one of them is a 1.2xx 60 foot. Lighter is better......
mdabbott2009
Now with this being hypers are they 5/64 or 1/16 rings? Any special hone jobs to help keep rotating friction down?
vortecpro
Post by vortecpro »
mdabbott2009 wrote:Now with this being hypers are they 5/64 or 1/16 rings? Any special hone jobs to help keep rotating friction down?
5/64 ring grove, round strait hone with clean Sunnen oil, nothing special.
wyrmrider
Post by wyrmrider »
vortec
how about a plateau hone
I use a Sunnen
vortecpro
Post by vortecpro »
wyrmrider wrote:vortec
I use a Sunnen
280 grit to size, then I go to a 400 grit, delrin shoes, clean the stones, then spray them with super tech carb clean, take two strokes then scotch brite in the hone with very clean sunnen hone oil.
Block passed the sonic ck very nicely, cam tunnel will work, block prep then the line hone, the heads.......well thats going to be a restoration.
mdabbott2009
All I can say is holy clean
cjperformance
Post by cjperformance »
He doesnt actually use that work area, that ones just for photos! :lol:
Keith Morganstein
Post by Keith Morganstein »
I was wondering about that. With getting the hypers lightened, it's getting close what a forged piston like an icon 779 with better ring package would cost.
Im sure it will still run good tho...
vortecpro
Post by vortecpro »
Keith you make a good point, and I considered those pistons, but.........how could I run the 1.2 MM ring I want to run?
Anyone have any HP predictions?
mdabbott2009
Probably more then my 781 489ci 246 solid roller
CamKing
Post by CamKing »
vortecpro wrote:Keith you make a good point, and I considered those pistons, but.........how could I run the 1.2 MM ring I want to run?
It won't make anything, if you don't stop posting about it, and finish it. That cam's gonna be an antique by the time you get it running. :lol:
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
bigfoot584
Post by bigfoot584 »
Well it's not just me then thinking the same.
Ever thought of doing a reality show.
Most be a member of ON & ON.
Good luck with the build anyway.
AMXstocker1
Post by AMXstocker1 »
I thought vortecpro on class racer and camking on here where the same person until this post.
