Don't bother with a HYD cam.. You are all set with this cam.hereinmissoula wrote:236/243 @.050"
.335"/.337" Lobe Lift
108 LSA
Mech flat tappet recommendation from Mike .
I like it , smaller than what I thought
Notice it is very close to the .050" duration of that Snotty Comp Magnum street roller cam I mentioned. (238-246 @.050")
It is about as close as you will get to that but in a good Mechanical flat tappet cam.
Be sure to verifiy the springs installed height on your heads. I would actually be nice to remove then and get them checked for pressure. A local machine shop will do this. Mike Jones will give you his seat and open installed sparing pressures etc.
Degree that cam in. On BBC's you want it installed right.
That BBC Chevelle is going to run very good.
post back when you get it all done. Get some Hot'n sticky tires and header collector extensions...
