wyrmrider wrote:really changing the subject now as the last question depends on heads, cam, etc
IDK about making the max compression work vs the 14.5
As posted above some restricted classes would die for that high compression and it could work with a lot of work and give you a few more hp- but I'd do it only in a competitive heads up class
what heads?, get the flows and get together with Jones on the cam- he may have a been there - done that on the compression He will give you an excellent "second opinion" on your build"
what rockers etc
from the start .the car is a 3550 lb street/strip car was running 9.50@143 with a little spray 11.6 comp deal ,i was doing a new engine for it hoping to go 8.9 but the heads i was using was found to have 8 leaking cracks in them i have had the heads repaired b4 6 leaks then ,so i mocked up the ex prostock head which has no leaks ,but the comp is to high ,the car sits most of the time and does not do much racing or street driving and i do not race any class .but i do like driving my car to the track and driving home only 50 mile trip . i am not a fan of e 85 yet but it is cheap ,the fuel i have been running will handle 15.1 ,my old combo had 11,6 comp 256/262 050 on 107 l/c 420 lobe heads went 325 @700 and 1.6 rocker 230 cc intake runner 59 cc chamber ,the xps head goes 400 cfm@700 298 cc intake runner 36 cc chamber 1.85 intake rocker and 1.7 ex 440 lobe 276/284@050 800 lift .i like running full street trim .thanks
