I like the ACT twin, there mildest one will hold 850 lb ft. and the pedal effort is like stock.
It is money well spent in the long run.
turbo play
- New Member
- Location: In Stephenville, Texas, USA from Thunder Bay, Canada
Re: turbo play
In Texas we have 93 octane. I would run e85, but.the closest place to me is 35 miles away.MileHighMan wrote:FWIW,,I didn't catch fuel type,, but if your using 91 pump and no I/C,, I'd strongly suggest a water/meth system on builds like that before shooting for more boost....Tuned right,, you should get to 15lbs pretty easy with no damage....as Joe 90 said,,you will be around double the factory rated power.....Dan
As I'm approaching 40,I still think I'm 20. What the hell is wrong with me?
Re: turbo play
I'm sad to spend, but beginning to accept as I tune this better $800-1200 for a decent clutch is well worth it if I plan on twin turbo...clutchdude wrote:I like the ACT twin, there mildest one will hold 850 lb ft. and the pedal effort is like stock.
After a certain point maybe I should pull the six speed for another project. And. Put half that into a thm 400. Hahaha .. naw, hahah.. I'm addicted to having overdrive
