Go look him up.dll67 wrote:Yeah .. Hes across the puget sound from me.
Tell him I sent you.
.002" is about my limit as well (depending on lifter size). Not sure as I have never done it, but can you coat lifters like you do pistons to take up the clearance?? That way you can true the bores up and be good to go again.dll67 wrote:OP
Update...
Cam is with mike getting cleaned up. Havent heard from him about any new insight into the damage to cam.
Lifters are at Morel getting inspected/rebuilt. Havent heard from them either.
Pulled the motor from the car and removed the passenger side head, the side that appears to have slightly more lifter bore wear, and measured the lifter bores. Ill do my best to explain my measurements.
Not having the actual lifters there is a margin of error. They are all well within .0002 of there min. and there max. measurements. I measured along the thrust from the top down.
From the top of the bushing down approx. 3/32 was very near the max dimension I could find anywhere in the ID of the bushing. Within or outside the area of thrust load from the cam. Which was .0018, =/- .0001 on all 8 pass side lifters.
From 3/32 down to within an 1/8 of the bottom of the bushing they measured .0019, +/- .0001 on all 8 pass side lifters.
From 1-5/8 down to 1-3/4, bottom of the bushings, they all got ugly. They all go from .0019 to .0024, +/- .0001, in that 1/8" at the bottom of the bushing. As heavy as the wear looks, its only about .0001, at the top of the bushing anyway. The bottom 1/8 is a different story.
The bushings dont hang into the cam tunnel.
What do you all run for lifter clearance??? What is a realistic limit to clearance, assuming I could hone them and maintain round. To my knowledge .002 is the limit, am I correct?
My dry sump pump is running the lightest spring with 2 coils cut off, still leaving a medium and heavy spring to combat the extra clearance.
I'll have to wait to do anything about the bushings till I get the lifters back.
Not sure today, but 40 years ago I understood Delo 400 to be a "low ash" diesel engine oil, similar to aircraft oil, no metallic additive, no Zinc or Calcium, but has high detergent/dispersant behavior. It was a common trick to use Delo 400 to clean up a sludgy engine that had sticky hydraulic lifters, but always added a can of GM EOS with it to get the Zinc and Calcium additives.dll67 wrote:Delo 400 for the wear additives .. 30wt
OPwyrmrider wrote:start here
" loose Jesel cam adapter was what allowed the roller cam to walk and was absolutely the cause for the lifter bore wear."
