Ported Chevy 049 heads
Re: Ported Chevy 049 heads
I would love to see a roller cam in this. Not a fan of flat tappets at all. I know they work, they can make power and some even last.
Charlie, is this the calculator you use to compare results? http://www.wallaceracing.com/area-under-curve.php
Pro question poster.
Yes it is. The numbers are different than if you just average them. I am sure he has his act together with his calculators.Bob Hollinshead wrote:Charlie, is this the calculator you use to compare results? http://www.wallaceracing.com/area-under-curve.php
I know it would not help out bob, but it might be educational to see how much flow would be picked up putting this head on a 4.5 bore fixture. or any bigger fixture for that matter. Just to see how much the flow increases due to the bore size change.
Paul
Paul
My fixture is a fixed 4.3" bore. Still thinking of how I can make smaller bore size sleeves that will stay put.FC-Pilot wrote:I know it would not help out bob, but it might be educational to see how much flow would be picked up putting this head on a 4.5 bore fixture. or any bigger fixture for that matter. Just to see how much the flow increases due to the bore size change.
Paul
Just found this old post from Larry. Feeling a bit better about these and my two sets of 781's.
I agree Charlie, doesn't appear to be much left to go after other than maybe at really high lift ranges but at the expense of lower lift flow I bet.
Lets put Larry's statement into perspective. .070 over 454s with flattop pistons, peanut port 236 heads, 2.065/1.720 valves, and QuadraJets make 720 STP corrected HP. The same setup except for 049/781 heads make 740 corrected STP HP.Carnut1 wrote:Just found this old post from Larry. Feeling a bit better about these and my two sets of 781's.
Experiment: install 2.19" valve no back cut install 1.88"exhaust no back cut and no rounded face. Check flow.
Experiment: Install 2.3" valve small back cut. Check flow.
It looks like the rounded face on the exhaust helps quite a bit?
No doubt.I always liked that mod. David Vizard mod I believe.Bob Hollinshead wrote:It looks like the rounded face on the exhaust helps quite a bit?
vortecpro wrote:Lets put Larry's statement into perspective. .070 over 454s with flattop pistons, peanut port 236 heads, 2.065/1.720 valves, and QuadraJets make 720 STP corrected HP. The same setup except for 049/781 heads make 740 corrected STP HP.Carnut1 wrote:Just found this old post from Larry. Feeling a bit better about these and my two sets of 781's.
I will guess this is one of your combos, Mark?
I am guessing Mark is trying to illustrate that it is the total combination and attention to detail that is going to get results not just good head flow numbers and I get that. I think he finds 50hp in just his oiling system mods LOL!
Bob Hollinshead wrote:I am guessing Mark is trying to illustrate that it is the total combination and attention to detail that is going to get results not just good head flow numbers and I get that. I think he finds 50hp in just his oiling system mods LOL!
If that is true that is amazing.
