.036 quench
.036 quench
I've read a little about this in another post but wanted to start my own, what are everyone's thoughts on this? Specifically a Chevy 383 6500rpm motor good steel rods and a 4.060 bore .036 thick head gasket on a zero deck? I know it's kinda splitting hairs just trying to get compression where I want with what I have. Any info is appreciated, thanks.
Re: .036 quench
What is your piston to wall clearance? You are cutting it close.... I like .040 but you might be ok >Once carbon gets on top of pistons .....
Re: .036 quench
What type of head and where is the spark plug located?
Adger Smith
903 794 7223 shop
903 824 4924 cell
adgersperf@aol.com e-mail
903 794 7223 shop
903 824 4924 cell
- Show Guest
Re: .036 quench
My sixty years of engine building has shown me that the extra close deck is worth NOTHING-- Whey do it ?
JOE SHERMAN RACING
JOE SHERMAN RACING
Re: .036 quench
OK fair enough just thought I'd run it past ya, I'll go with .040 or so, thanks. Will a 4.060 bore gasket be ok on a 4.030 bore? MlS gasketbigjoe1 wrote:My sixty years of engine building has shown me that the extra close deck is worth NOTHING-- Whey do it ?
JOE SHERMAN RACING
Re: .036 quench
Joe, you'd know on high horsepower builds. I do know staying under .050" is worth doing when trying to control ping on lower horsepower, lower RPMs iron head street engines. Different horses for different courses.bigjoe1 wrote:My sixty years of engine building has shown me that the extra close deck is worth NOTHING-- Whey do it ?
JOE SHERMAN RACING
- Show Guest
Re: .036 quench
That Is what I have seen too. anything like 055 or less seems to work out very well. I never push to see how close I can get
JOE SHERMAN RACING
JOE SHERMAN RACING
Re: .036 quench
There are combinations that "Bigger IS Better"
Adger Smith
903 794 7223 shop
903 824 4924 cell
903 794 7223 shop
903 824 4924 cell
Re: .036 quench
My 5.7in rod, 9.5:1 383 has piston .015 out of bore and .050 gasket thickness. We'll see how this works.
Re: .036 quench
I ran a 4.040" bore 3.5" stroke SBF with the piston .005" out & a .043" compressed gasket for years with no issues. Shifted at 7200 but it hit the 8000 high chip many times on missed shifts before I swapped out the worn out toploader for a C6.
Re: .036 quench
I agree, in highish HP deals not worth chasing it. Run it .040 ish and let it eat!!
However, in a restricted engine, say a 2bbl. deal, it does have some benefit. I have run .030. you better have fairly tight piston to wall though. Piston will touch the head @ 7400. Just "helps" it turn around and go back down!! LOL
