043/043 vs 1/16 1/16 ring packs
I posted on here about a year ago bout doing a L88 engine for my Camaro for bracket racing locally.
I decided to go with a 4" stroke . So ill be running 466 CI
Compression should be in the 13.2:1 range.
Trying to decide on a ring package.
What would the hp advantage be going with a 043/043 ring pack vs the 1/16/1/16 pack? approximently ofcourse...
Would it be 5hp? 15hp??
And whats your opinion on going with a 3mm low tension ring vs a high tension??
Thankyou.
Thankyou.
Re: 043/043 vs 1/16 1/16 ring packs
With up to about 70 feet per second average piston speed you won't see much difference, if any at all. Higher piston speeds will show some more power with the thinner and lighter rings.
- Show Guest
I have seen much more than that. The thin rings with vertical gas ports and a vacuum pump I have seen over 50 more horsepower
JOE SHERMAN RACING
JOE SHERMAN RACING
X2 - ring flutter occurs at higher RPM with thinner rings.
Panic, could you please elaborate?panic wrote:Higher piston speeds will show some more power with the thinner and lighter rings
By the looks and sounds of things, My piston guy @ CP says go 043/043 and gas ported and I will be going a faster vs a standard 1/16 1/16 no gas ported route.
The motor will be seeing 7-7500 rpm.
Stepping in on above: At high RPM a thick ring has more momentum than a thin one and so as the piston slows approaching TDC, can more easily become unseated from the bottom of the groove. This causes the sealing pressure on the back of the ring to be lost, so the ring 'collapses' (loses much of its loading against the cylinder wall). Happening repeatedly as it does, it is described as 'flutter' and is bad for cylinder sealing and ring durability.roc wrote:Panic, could you please elaborate?panic wrote:Higher piston speeds will show some more power with the thinner and lighter rings
+ Gas ports help stop ring flutter as well by keeping the ring loaded .
Better yet go with something like mahle has 1mm 1mm 2mm. i've had great luck with it so far.
Did you change your cylinder wall finish at all?
As compared to:
.043 x 3
1.5 x 3
As compared to:
.043 x 3
1.5 x 3
I Will do whatever the piston/ ring company recommends. The rings came from TOTAL SEAL.
