Another "How much will it make?" Project "Special Needs"
n2xlr8n
Re: Another "How much will it make?" Project "Special Needs"
Post by n2xlr8n »
CGT wrote: Mon Feb 19, 2018 12:44 pm
n2xlr8n wrote: Mon Feb 19, 2018 11:19 am
CGT wrote: Mon Feb 19, 2018 10:13 am Any guesses on what much better ring seal on special needs will be worth power wise?
26.313 HP.
You're going to have more friction loss. :wink:
Negative 26.3 or positive 26.3? :lol:
Roughly. :lol:
I honestly would be surprised if it didn't surpass the 600 mark with good seal and a vacuum pump.
Wanna try a electric Vette pump? I have one I'll loan you for SN testing purposes.
CGT
Post by CGT »
n2xlr8n wrote: Mon Feb 19, 2018 3:23 pm
26.313 HP.
Roughly. :lol:
I appreciate that. Have you used one and if so how much vacuum was it capable of?
In-Tech
Post by In-Tech »
I'm curious for more details of this electric vacuum pump as well. What engine hp and size of engine/brand,etc. Sheesh I need to get out more. #-o
-Carl
n2xlr8n
Post by n2xlr8n »
CGT wrote: Mon Feb 19, 2018 8:24 pm
Roughly. :lol:
I posted it here somewhere- I think it was 5-6", but my methodology was not the best. A started using them in 2003 when I saw them on many of the Outlaw 10.5 cars around here. Not having access to a dyno personally, the only thing I noticed was the plugs looked better (low 9 street car), and I it idled better.
In-Tech wrote: I'm curious for more details of this electric vacuum pump as well. What engine hp and size of engine/brand,etc. Sheesh I need to get out more. #-o
It's likely not what you guys are used to, but it worked well on my SB, BBC and Subarus (terrible CCV and sealing issues).
...and they are cheap- both the pump and harness can be had from Delco distributors for less than $200.
CGT
Post by CGT »
n2xlr8n wrote: Tue Feb 20, 2018 8:02 am
Roughly. :lol:
Are you using part # 12554580?
n2xlr8n
Post by n2xlr8n »
CGT wrote: Tue Feb 20, 2018 9:12 am
The PN on my box is GM 24505066 air pump, 95 Corvette, but your PN certainly is a clone of the pumps I've used.
GM 12117025 Harness
1) Remove the large black plastic cover from the pump. There are three tangs and silicone sealer holding the two halves.
2) Remove the dense foam surrounding the pump housing. In the event a large amount of oil is aspirated, the foam will cause pump meltdown...don't ask :lol:
3) Remove the small green solenoid entirely from the circuit.
Hot=ORG
GND=BLK
I would strongly suggest using a relay with this pump; it pulls a bit of current.
CGT
Post by CGT »
n2xlr8n wrote: Tue Feb 20, 2018 9:56 am The PN on my box is GM 24505066 air pump, 95 Corvette, but your PN certainly is a clone of the pumps I've used.
GM 12117025 Harness
24505066 is now discontinued. Your harness number is still good though. I may get a 12554580 and see what it looks like. I doubt it will pull the amount of vacuum that I'd want. But I can see it being nice for somethings I mess with.
CGT
Post by CGT »
Dyno results coming soon.....again :D
RevTheory
Post by RevTheory »
Hey, you got 'er painted AutoZone orange :D
That intake/carb/spacer looks like a beast. Are you still twisting it up around 7k?
CGT
Post by CGT »
RevTheory wrote: Wed Jun 20, 2018 12:47 pm Hey, you got 'er painted AutoZone orange :D
The spacer is an HVH I recently acquired, the 1050 I just had jmark go through for a dyno carb for all of us to try. Neither one are specifically for special needs. Just set them on there to get them off the bench. I may test the dominator on it, but it will most likely have a 4150 on it for most of the tests. RPM will be the same as previously 3000-7000.
GARY C
Post by GARY C »
CGT wrote: Wed Jun 20, 2018 12:51 pm
Hurry Up! =D>
randy331
Post by randy331 »
CGT wrote: Wed Jun 20, 2018 11:46 am Resized_20180614_204944.jpeg
Actual dyno results ????
Why bother?
You should be able to run your flowZ and cam, or maybe just IVC on some program and know what it will make. :D :lol:
That carb up for pulling truck duty ?
Randy
CGT
Post by CGT »
randy331 wrote: Wed Jun 20, 2018 3:50 pm That carb up for pulling truck duty ?
Sure. If my results don't agree with theory, go with the theory? Is that right? In all seriousness, she should be good to go.
paulzig
Post by paulzig »
Dominators look good on small blocks,
609.667HP @ 7011RPM, 510.036TQ 5445.19RPM.
cjperformance
Post by cjperformance »
CGT wrote: Wed Jun 20, 2018 4:07 pm
1050÷128=8.2something ,, yep good to go!
