I.dont want to make feel worse than you do.....but its probably much worse than you think. Your making 532@6800 and this thing is doing just about that at a much lowet rpm. This makes 512 ft lbs at 4800, 492 at 3500....ill bet your tq is know where near that!!steve cowan wrote:hey guys,here is another example of a few guys who get the job done,my recent build is a 383 sbc dart heads titanium everything ,makes 532hp @ 6800rpm what a joke i have got nothing on you randy,i read posts from you,big joe and melway here in australia and i am not trying to piss in your pockets because what you guys do is give me motivation to try harder and look outside the box and that i thank you guys for.
Pseudo racing engine surprise
Re: Pseudo racing engine surprise
At some point yes there will some ported heads/intake on Pseudo. (then it will be re-named) Won't happen this year, got too much to do right now. I gained work today in fact. I went to red lobster for lunch and when I got home there was a set of LS3 heads sitting at my house. Figured after I told that guy what I'd do on the LS3 heads he'd be running from my shop.CGT wrote: Randy, surely your not going to leave that thing in unported, unrefined form? Any plans for recamming or head or manifold work? Think that thing would run better in that rpm range with less exhaust duration?
On the cam,...? the ex lobe on the pseudo cam is a solid roller lobe and it has a hyd roller lifter on it, so it has lots of seat duration on the ex side. But it still liked the 1.6 rocker on the ex over the 1.3 rockers and lost nothing at the bottom of the pull. When the cam was in 6* advanced it made a bit more at the bottom and the EVO at the seat would be 87* BBDC with the cam in that position. I may get some really odd cam for it to try, like a 240*/275* on 112* LSA. Be interesting to see that on the dyno. Track testing a cam like that won't tell me what it did to the bottom of the power curve. Then after porting the heads and intake it'd be interesting to see how different the results were between those 2 cams.
That guy probably isnt quite right, he should probably anticipate smaller valves and epoxyrandy331 wrote:I went to red lobster for lunch and when I got home there was a set of LS3 heads sitting at my house. Figured after I told that guy what I'd do on the LS3 heads he'd be running from my shop.
Interesting, thats a very early EVO, but I am starting to see that trend here and there. Im sure there may be point where too early may hurt low speed power, but I suppose that point may not be as early as one may think. I know GM has headed that direction. Of course they have other considerations besides overall horsepower.gmrocket wrote: When the cam was in 6* advanced it made a bit more at the bottom and the EVO at the seat would be 87* BBDC with the cam in that position
Dang! The way your Nova runs makes me want to burn my car! I'm not much faster, with a what I think is alot more engine.
Below is the best pull made with each of the 3 rocker combinations we tested. We made at least 2 pulls with each combo.OILEAKY wrote:Randy, how did it run with those 1.3 rockers ? Just curious......
Left column is 1.3 ex and 1.3 in
center column is 1.6 ex 1.3 in
right column is 1.6 ex 1.6 in
We didn't test 1.3 ex and 1.6 in. There's always more things to test and more questions at the end of every dyno session.
Code: Select all
rpm 1.3/1.3 1.6/1.3 1.6/1.6
3500 326 327 329
3600 337 335 334
3700 342 340 341
3800 349 350 350
3900 354 359 361
4000 364 371 370
4100 378 384 382
4200 390 394 395
4300 403 410 407
4400 412 422 423
4500 427 433 431
4600 436 444 444
4700 449 453 455
4800 456 462 463
4900 463 468 471
5000 466 474 475
5100 470 480 485
5200 481 484 489
5300 487 488 498
5400 483 498 504
5500 487 487 504
5600 492 504 511
5700 491 502 517
5800 494 506 521
5900 495 507 518
6000 492 502 524
6100 487 508 515
6200 487 506 515
6300 489 505 515
6400 481 503 517
6500 481 503 508
That seems a little extreme !!!408 Nova wrote:Dang! The way your Nova runs makes me want to burn my car! I'm not much faster, with a what I think is alot more engine.
- jmarkaudio
We did something similar about 20 years ago. Dish piston 406 on 93 pump gas, production vortec heads with only bowl cleanup and 1.94/1.50 valves, a large Crane FT hydraulic cam, SV intake and a Dominator, 2800 lb Malibu with a 4.30 gear and 32" tires. 10.60's all day long.
Mark Whitener
www.racingfuelsystems.com
____
____
A light weight race car is a nice thing. My simple 9.8:1 ported 062 vortec head hyd cam 406 would run very similar when
in a 2800 lb drag race car with race converter. Especially if changed to 11.4:1 and 100 octane.
The vortec heads work pretty good. And the Bowtie vortecs are even better.
A rocker arm ratio increase shows typical more power especially if/when the camshaft is small- under sized
for the purpose. If the cam is more correct duration to start with, the rocker ratio change
will show a lot less power gain. This cam is small for a racey motor..... so...
Nicely done stuff irregardless Randy331
It's interesting that the horsepower gained from changing the 1.3 rockers to 1.6 ones, gaining about .110 more lift at the valves, only netted about 6% more HP @6500, and 2% at 5000 rpm. ( if my math is right !) Those are some good heads !
Nice job on that engine combo Randy, you will surprise many with its performance. Question--what did the power numbers come in at with the 1.3 rockers? And have you considered some thicker trans oil for stall speed help? A lot of the turbo buick guys I know use the john deere hygaurd with good results. Seems like 200-300 tighter might be more on a 500HP build. Mannie Just saw the rocker post
No, it's whatever they are as GM sent them. My guess would be about 1.75" csa at pushrod, but I don't know for sure.rewguy wrote:Did you measure the area at the PR? Just curious is all.
I thought the gain was a decent gain considering the heads are un-ported. The heads flow no more air at .600" lift than they do at .475" lift, so the only gain would be from time/area. Likely be different results with the heads ported, but know way to know for sure without testing it.OILEAKY wrote:It's interesting that the horsepower gained from changing the 1.3 rockers to 1.6 ones, gaining about .110 more lift at the valves, only netted about 6% more HP @6500, and 2% at 5000 rpm. ( if my math is right !) Those are some good heads !
So lifting the valve into port stall on both sides netted power increases?
