Hello everyone,
Using Wiseco pistons in a 15:1 555 BBC drag racing engine...manufacturer calls for .0052 piston to wall clearance..
I had my block honed recently and ended up with 4.562 bore...
seting an outside mic on the piston skirt where Wiseco says to measure....then zero a dial bore gauge to it and use it to measure the clearance in the bores.
I end up with .0085....is it safe to run that loose or what can I do to bring the clearance down to the .0052 or so area?
Thank you.
