Did I miss something?wyrmrider wrote:
But try running that Chevy/ Crane guy's method at high rpm with a big cam and...
I have no idea what you are saying????
Only 20 of them there should we just pick one & go with it.wyrmrider wrote:look at the other videos on the right of the one we are talking about
I'll divide the valve tip into thirds. If the sweep pattern falls somewhere in the center third, I'm plenty happy with that. If it's on the edge of that third, I'll live with it. If it's outside that third, I think something should be dome to try and correct that.buddy rawls wrote:I liked the video too. I have never done it that way beither. the midlift 90 deg is the point of tangency to the valve line of action. this is the same thing that is accomplished with the narrowest wear pattern. By definition, the narrowest wear pattern is as near to tangency that can get.
Scott's method works very nicely, it is definitely less subjective. but in the engine compartment can be a little bit of a hinderance. I think I will head towards that method, or atleast a hybrid of the two. thanks for the doing that video.
The big question I get confronted with is how much off-center is really permissable. I can do engineering and eccentric load calcs, but often times people just want to know how close can you really get to the edge. Optimally, I say to break the valve tip diameter (not the valve stem diameter) into thirds, and try to stay within that middle third. But at the absolute max, into fourths, and stay within the middle two, but absolutely no more.
Its kind of spring coil bind. I have target values and I have absolute minimums.
Well put.buddy rawls wrote:the best durability and transfer of motion is when the valve's line of action (which may or may not occur dead-on the valve's centerline) is as closely aligned to the rocker arms sweep path as possible. In other words, the valve's line of action is tangent to the rocker's sweep arc. this is accomplished when the wear pattern is as narrow as possible (period). draw it out, with the multiple angles, and the narrowest wear pattern by definition occurs when the valve line action coincides with the rocker sweep path.
If this wear pattern location occurs too close to the edge of the valve stem, then some part of the set up has to be changed. rockers changed, valve heights changed, even lash caps can be used. But it does not change the fact that narrowest pattern is the best transfer of motion, it simply shows the asbuilt geometry cannot get there.
Wide wear patterns are from the valves line of action not being tangent to the rocker sweep. This really puts an off-axis load on the valve, even with a roller rockers. Draw out the sweep path and and lift envelope and alter the valve centerline angle to adjust the wear pattern path. You can easily notice the rocker arm is not pushing in line with the valve.
Forcing a wear pattern to the center of a valve tip does nothing for geometry whatsoever. Ending up with the narrowest wear pattern and it happens to land center of the valve stem is perfection that can only happen if all the pieces fall together exactly perfect; a rarity. Hower, centering a wide wear pattern on the center of the valve stem is possibly a recipe for disaster.PackardV8 wrote:Only slightly off-topic, but how often do you find yourself having to choose between the perfect mid-lift pushrod length and the one which gives the most-centered stem tip wipe pattern?
If things just dont work, there may be a wrestling match between the narrowest pattern and the edge of the stem, but centering the wear pattern should not be part of the discussion.
