X pipe
Re: X pipe
The location of the X pipe will determine performance gains. You don't just add an X pipe and get a gain. Finding the right distance from the collector can be a pain so I personally didn't bother with one.
Re: X pipe
Has anyone experimented with an X pipe on a traditional V twin Harley? This would be to keep most of the dual pipe look, but improve performance.
Re: X pipe
That I would like to hear.Keith Morganstein wrote:Has anyone experimented with an X pipe on a traditional V twin Harley? This would be to keep most of the dual pipe look, but improve performance.
Ken
Over the hill but still learning!
Retaining it is the hard part.
Re: X pipe
Keith,Keith Morganstein wrote:Has anyone experimented with an X pipe on a traditional V twin Harley? This would be to keep most of the dual pipe look, but improve performance.
Surely you have seen 2into1 pipes for harleys. There is absolutely no need to have an x or crossover and two tailpipes for performance.
Calvin Elston
Elston Exhaust
Matthews, NC 28104
346-704-4430
Blog: www.exhausting101.com
Elston Exhaust
Matthews, NC 28104
346-704-4430
Re: X pipe
Re: X pipe
someone asked about the sound of 8 into 1 - I saved this link from a thread on speed talk a long time ago. I am almost certain it was said to be 8 into 1...would be better without the music, but you can get a pretty good idea
https://www.youtube.com/watch?v=5OS_k0V ... rUKwb4WhKA
there are a few others if you search youtube...
HTH's...
HTH's...
Re: X pipe
So how does an 8-1 work on a v10 exactly?job1bf wrote:someone asked about the sound of 8 into 1 - I saved this link from a thread on speed talk a long time ago. I am almost certain it was said to be 8 into 1...would be better without the music, but you can get a pretty good idea
HTH's...
Also, if you go to 0:35 you can see the 5-1 collector on the one bank, or at least what looks to be 5-1 since you can't exactly count the hidden pipes.
Re: X pipe
Here is one of the cars Calvin builds headers for. The 4-2-1 headers all dump into a single 3" pipe, I believe.
https://www.youtube.com/watch?v=NELSera ... E84O_2c7pA
Bill-C on here is the engine builder.
-Bob
Re: X pipe
===================exhausted wrote:Not only does it sound like and engine with a flat crank, the engine runs like it has a flat crank in it...englertracing wrote:cgarb wrote:
makes it sound like
an engine that actually has a 180 crank
Except the secondary vibration stays low, to the possible benefit of driver and auxilliary equipment.
Re: X pipe
Oops...sorry about that..not sure that happened..here is the correct link...Rizzle wrote:So how does an 8-1 work on a v10 exactly?job1bf wrote:someone asked about the sound of 8 into 1 - I saved this link from a thread on speed talk a long time ago. I am almost certain it was said to be 8 into 1...would be better without the music, but you can get a pretty good idea
HTH's...
https://www.youtube.com/watch?v=OxQAz_t ... rUKwb4WhKA
Re: X pipe
Here's a 428 FE going 0-135 mph with an x-pipe, 3.5" exhaust, and Dynomax Bullets. I just put the x-pipe as close to the header collectors as possible, so I'm sure it's not optimal. It did quiet the exhaust some. And I like the sound.
http://vid231.photobucket.com/albums/ee ... c79ad5.mp4
The narrative is not correct. The actual 1/4 mile time was 11.49 at 124 mph according to the G-Tech. Horrible launch, in and out and back into the throttle in 1st gear. That's why the time is so bad for the mph. Street tires and all......
I suppose this doesn't help with the OP's question, but I thought the sound might be entertaining. I'm shifting a 7000 rpm or a bit less.
paulie
paulie
- ItalianJohnny
Re: X pipe
Which Mufflers ???66Vette wrote:I get the same comments on the sound of my car. It has a Dr Gas X-pipe and mufflers. Engine is a 374CI (4.125 x 3.5). People come up to me after a run (autocross) and always ask about the unique sound.
Re: X pipe
Yes and of course and they perform the best. Problem is many owners don't like the Look of a 2-1exhausted wrote:Keith,Keith Morganstein wrote:Has anyone experimented with an X pipe on a traditional V twin Harley? This would be to keep most of the dual pipe look, but improve performance.
Re: X pipe
When running Pipemax for my combo it suggests a H pipe 19.3 inches from the primaries, but the X pipe 77.3 inches from the primaries.
Jim
