cam info
cam info
Looking for some insight on cams and what it all means. I know enough to get myself in trouble but need a lot more schooling. I'm running a 379 sbc and wondering what to do. Afr 220 heads, 13.5 compression, super victor 2 intake and a Barry grant 825 carb. It's in a pull truck and I would like to be able to run 8,000 plus and have the power to keep the rpms up at the end and not get sucked down. Any knowledge you guys are willing to share would be great. Thank you
Re: cam info
motor already built?
what cam?
where do you need more?
what rocker arms?
how did you measure compression, cc the heads?
what's your quench
what kind of cam?
for no bs
http://jonescams.com/tractor-pull/
what cam?
what rocker arms?
what's your quench
what kind of cam?
for no bs
Re: cam info
I'm afraid I don't know much about the ' GO ' gear your talking about, BUT. ... sounds like you need good torque and HP @ 7 - 8000 rpm
Here's a guess, say about 546 hp @ 6900 - 7100 TQ band should be reasonable, beyond those revs ?
Maybe careful gear selection and tampering with the tq curve ex / in pipe lengths, cam position etc would help
IN 290* 36-74 70-32 EX 282* @ 0.006" lift .610"
you might be able to use a more aggressive lift rate on the EX lobe as the valve is much smaller
Hopefully someone else will pitch in, I'm possibly of track here ?
Re: cam info
Solid roller cam. My big issue right now is at the big end of the track where it really bites in and I don't have enough to grunt out that few extra feet. Any info on duration, lobe separation, ramp speed. What it all does and what each part of it benefits or how it can hurt. Looking to learn
Re: cam info
Please call UDHarold here at 662-562-4933 and ask him what you need.
He will tell you just exactly what you need!!
And if you do, please say hello from ol' pdq67 for me.
Re: cam info
please let us know the result ... tapdq67 wrote:Please call UDHarold here at 662-562-4933 and ask him what you need.
Re: cam info
No test results as my pulling season is over. I originally started this topic trying to learn what each aspect of the cam spec did for performance like too much lift, not enough lift, duration, lobe separation not enough or too much
Re: cam info
Best to work with mike on a pull truck and most everything else unless you have lots of experience and/ or customers experiences where you can call your own shots
pioneers are the ones with arrows in their backs
- New Member
Re: cam info
Would be good to see that discussion. How about posting the old cam specs for comparion to the one spec'd above?freddiejip wrote:No test results as my pulling season is over. I originally started this topic trying to learn what each aspect of the cam spec did for performance like too much lift, not enough lift, duration, lobe separation not enough or too much
Re: cam info
also were your heads out of the box or ported and what exhaust?
Is there a tranny
if so what is your rpm drop when you shift- what does the rpm drop down to?
Is there a tranny
