kirkwoodken wrote:Here's a quote from Gordon Jennings "Two Stroke Tuners Guide":
"Yamaha's TD-series racing engines, for example, must be timed plus or minus only
0.0012-inch of piston travel from the specified distance of TDC."
This is an example of a highly tuned race engine. With a power loss 0.0012" on either side of recommended timing, how close must TDC be determined? I'll bet it's better than 1/16" of screwdriver movement. I'm not trying to be a jerk, just showing how important knowing TRUE TDC can be. This is not some compromisable dimension. It either is or it isn't.
But does Yamaha use a sloppy timing chain driving a 24" metal shaft which drives a 9 tooth distributor gear driving a spark distribution device which at a minimum differentiates 2-3 degree's when it is all brand new before any stretch and break in wear occurs. Also What is the dwell time in degree's inc the .0012 before and after TDC for instance with a 5.700 con rod with a 3.50 stroke crankshaft at .001 before and after TDC dwell is approaching 5 degree's that's 2 1/2 degree's before and after true TDC so shorter stroke with a shorter con rod has an even greater TDC dwell time so this means you will exhibit minimal or no power loss if you have the Yamaha timed in a 5 degree window? so how important is it to know your TDC on your average 4-500 HP street rod is precisely less than 1 degree off if your timing mark is 3 degree's off you will more than likely be within the Yamaha specification.
what you guys don't realize is I am a general mechanic I see from 3-to 20 different cars daily and it is common place for me to need to find TDC several times a week and there are many different applications that there just arnt a $8.00 piston stop available on the tool truck , the local Napa, or sears. I bet you cant buy a piston stop tool for a Hemi for $8.00. So how do you find TDC on a 5.4 ford or a toyota 5SFE it a late 2.3 Mazda MX3 there are other tools for these applications but you have to use the screwdriver method to get you close and I usually find that I am dead on or nearly at the correct crank angle when I install the crank stop or alignment pin.
kirkwoodken wrote:I'll bet it's better than 1/16" of screwdriver movement
If I couldn't differentiate anything less than 1/16 of an inch I think it would be time to hang my monkey wrench up and retire. A sensitive hand can feel as little as .001-.002 of movement. Can you touch your wrist and feel your heart beat? Can you lay a .001 feeler guage on a flat table and feel the difference in the smoothness of the table with your finger tips? So yes If I had someone rocking the crankshaft and I notated about 6 degree's of crank movement between the drop off's feel. I could set the crank in the middle of the 6 degree window and be sure I was within 1 1/2 degree before or after true TDC (totaling 3 degree's tolerance)
There are times when it is appropriate to use the proper tools to find TDC precisely but don't trash talk someone for half assing cause they don't do it the way you do.
What if Columbus had taken the popular view that the only way to sail around the would was to sail in 4 straight lines and 4 precise 90 degree right hand turns at the end of each line?
Where would NASCAR be if Columbus had listened to the Europeans?
Be careful not to box yourself into what some consider be narrow minded view. Look at it like this there is more than 2 ways to kill a bird with 2 stones
Wolfplace wrote:
Really,,,, What are you,, 10?
Silver spoon,,, 20+ million in equipment
WTF are you babbling about & what does anyones equipment have to do with anything here?
The point is you are privileged with every too you could every need and this could focus your view and narrow the options of how you approach a job or solve different problems
Sure you are through with this you are the one who started this robust discussion by trash talking me saying I half assed everything I do and had no place here because I have an alternative view of how to approach a problem that differs from yours. So piss off and let me have the last word if your EGO will truly let you be done with this
