A look at what current Comp Eliminator cars are running will show otherwise.
In fact, many are now using a reducing 'cone' at the end of the collector.
Case in point and this right here is the problem. As I mention time and time again, it is a monkey see monkey do. Comp eliminator is a strict rule book class, of which 90 percent of comp are small inch engine with large manifolds and very large carbs. Many are also backed with 8 to 12k transmissions with multiple gears so they can run within a 450-650 rpm range the whole way down the race track. Comp eliminator represents less than 0.5 percent of the actual drag race vehicles that actually participate week in and week out, and that is a over estimated percentage that I just gave. There are little to no sportman classes whereas you will see an engine that is 265-292 inches, or even 305 inches or even 338 inches. Your average engine now is 582 and greater. You know it and I know it. 6 years ago the average engine was 565 inches. You think your really going to find a comp car that pulls to the line with 565 inches. Even A/D or A/A is not that much cubic inches. Monkey see monkey do. everyone is looking at a select few that go fast.
LOL. What do you think 4-2-1 headers and merge collectors are all about? It's all about making more AVERAGE power, not necessarily more PEAK power.
Go put a one of those on a 598 or 632 that makes 1275hp and let me know how you make out.
That is your average engine now. they run 6.95 to 7.05 in a 1980 to 2050 pound dragster.
This is your average deal pictured below. It's 26 degree, 548 (4.6 x 4.125). cast manifold, single 1150 carb, brodix heads, bow tie block, 4 link dragster. I've tested lots of headers and different collectors as well. The initial primary's where between 25.5 to 27.0. The can is a scavenge. I increased the primary length by a net of 3.5 and the gains where pretty substaintal. The 60ft's went from 1.038-1.041 to a 1.017-1.021. The increased length of your typical produced header was not enough, and I have been working with increased primary's since the 80's, and all have significantly helped broaden that torque curve. The header company's never issues enough primary, and they do not because they don't build engines and what's most important is that they don't test really enough down the race track. I have had merges on as well on 548 to 640 inch stuff and I keep going back to the scavange with increased primary, or shall we say the correct primary length.
