Interesting Choice Of Break-In Oil
Post by 1989TransAm » Sun Jul 27, 2014 2:16 pm
The people building the LS3 based 427 short block for my car have recommended this oil for break in. I found it interesting. Any thoughts? Anyways it is being shipped with the short block.
Schaeffer Diesel Supreme 7000 10W30 para-synthetic.
#84Dave
Re: Interesting Choice Of Break-In Oil
Post by #84Dave » Sun Jul 27, 2014 2:43 pm
I always use Rotella Diesel oil to 'break in' my new-build 4 & 8-cylinders. Works for me! Gotta lot of that zinc stuff in it. -Dave-
coolchevy
Post by coolchevy » Sun Jul 27, 2014 2:49 pm
diesel oils are always a good choice to break in, like Rotella Shell the most as it is cheap and easy to get
pamotorman
Post by pamotorman » Sun Jul 27, 2014 4:39 pm
the "new" diesel oils have reduced zinc also because the new diesel engines have cat convertors. read the label carefully. also diesel engine oil do not have a lot of high pressure additives. I had a customer put diesel engine oil in a BBC short track engine back in the day and the engine was worn out in 2 nights of racing
coolchevy
Post by coolchevy » Sun Jul 27, 2014 4:57 pm
it should be used to break in engine the first few miles and not to run races ...
Meehan Race Engines
Post by Meehan Race Engines » Sun Jul 27, 2014 5:36 pm
I would not be using a current day diesel oil to break in any type of engine. Diesel oil is zinc rich but it's loaded up big time with detergents due to todays diesel engines are running emission equipment. Take a look a the attached links from Driven Racing Oil.
http://www.drivenracingoil.com/news/dro ... detergent/
http://www.drivenracingoil.com/news/dro ... -bulletin/
Gary Meehan
Meehan Race Engines
CNC BLOCKS
Post by CNC BLOCKS » Sun Jul 27, 2014 5:48 pm
#84Dave wrote:I always use Rotella Diesel oil to 'break in' my new-build 4 & 8-cylinders. Works for me! Gotta lot of that zinc stuff in it. -Dave-
Where do you buy the old Rotella with zinc in it as the newer Rotella that is formulated for the newer engines only has 970 PPM of zinc compared to the pre 2007 which had 1400 PPM of zinc.
I have been using the CENPECO 15/40 S-3 oil which has 1582 PPM of zinc.
Website is up and running
Machine shop tour
Monthly Specials
vortecpro
Post by vortecpro » Sun Jul 27, 2014 8:02 pm
LAT for me.
k-star
Post by k-star » Sun Jul 27, 2014 8:17 pm
There has to be a dozen or more manufacturers of oil specially formulated for the gas engine/break-in. I am amazed at the guys that want to use a oil designed for something else. Oh well, guess they know more then the guys that are oil Engineers.
“If I hit you with this you’re going to be numb, that’s why they call them numb-chucks “Si Robertson
wyrmrider
Post by wyrmrider » Sun Jul 27, 2014 8:57 pm
interesting tech bulletins at that site
BrazilianZ28Camaro
Post by BrazilianZ28Camaro » Sun Jul 27, 2014 9:13 pm
I do use diesel API CG-4 / SJ e ACEA E2-96 / B2-96 engine oil to break-in FT cams and also for drag race with success, because here in Brazil there are no performance oils available. Just snake oils additives. #-o
This oil being a old formulation,I figured it should have good Zddp content and more important, this same oil support the massive bearing loads 18 wheeler trucks engines are subjected to when loaded, accelerating uphill at low rpm; it might have enough film strenght to protect healthy V8.
Import lubricants is prohibited overhere, then only if a miracle happen I can buy a can of USA made Zddp to add.
'71 Z28
Pump gas N/A SBC 427
3308 lbs-29x10.5 Hoosiers
bigfoot584
Post by bigfoot584 » Sun Jul 27, 2014 9:13 pm
If there offering you a warranty, I'd run it if something goes wrong it's
one less thing for them to say you screwed up, and better chance it
gets fixed. Why would they say to run something knowing it will
ruin their engine. :roll:
k-star
Post by k-star » Sun Jul 27, 2014 10:00 pm
A lot of shops just don't know. I had no idea until I attended a seminar by Lake Speed from JGR.
I do not use the JGR oil, but it made me do my research on oils.
Post by 1989TransAm » Sun Jul 27, 2014 10:01 pm
I am going to run the oil initially. When the short block arrives I will see if there are anymore instructions with it. If need be I will call the shop up. I am thinking of something like Joe Gibbs 5W-30 break-in oil after the first oil change.
Strange Magic
Post by Strange Magic » Sun Jul 27, 2014 10:02 pm
Not amazed one bit. It's a monkey see monkey do type of situation, and so are many of the old wives tales that that they follow as well. The last oil I would ever use in an application pertaining to a street, street strip or race application, would be an oil intended for a diesel.
strangemagicperformance.com
